jferio, on Sun Mar 14, 2010 10:51 AM, said:
You can also add a different power connector if you're inclined... I've done that to mine, and my friend's unit, so that they can both take a standard 2600 power supply, or the closest available 'generic' supply that uses that sort of positive center tip. (1/8" mono headphone plug)
fiddlepaddle, on Sun Mar 14, 2010 6:51 PM, said:
Don't throw away the adapter yet. That connector is unique and you can just take another adapter with the same voltage/current/polarity and splice up the 7800 connector to it. Lots easier than finding a compatible replacement adapter (or another original that is 30 years old).
Underball, on Mon Mar 15, 2010 8:26 AM, said:
Actually, I would guess that it's the more likely the on/off button. The metal bubble contacts inside tend to get oxidated after a while, and stop working. But you can pop the plastic cap off them carefully with tweezers, and clean the metal dome and contact off with alcohol and a bit of fine sandpaper. them pop them back in, or just use electrical tape to hold them in place.
Thanks for replying guys!
I already ordered one on eBay, some guy is apparently making
new ones for a fairly reasonable price. It hasn't come yet, but I'll be sure to tell you guys about it when I do.
In the mean time, I'll have to try the on/off button fix tonight to see if that works.
Thanks again guys!
