I have troubles running some 128kB games under ProSystem 1.3 emulator (Win32). Ikari Warriors or Planet Smashers boot but both games lock up after intro, Midnight Mutants even doesn't boot. Where could be problem? I downloaded 7800.rom and .a78 cart images, set up BIOS and region to NTSC but I didn't get any further. I would really appreciate any help...
F.
ProSystem Emulator problems
Started by _Fandal_, Mar 15 2010 11:55 AM
5 replies to this topic
#1
Posted Mon Mar 15, 2010 11:55 AM
#2 ONLINE
Posted Mon Mar 15, 2010 12:00 PM
F.
F.
Have you tried 1.2, just as a quick check?
-John
#3
Posted Mon Mar 15, 2010 12:02 PM
What version are you using? The latest version is 1.3e which is available on the forum. I have found 1.3d to be buggy emulating two button joysticks.
#4
Posted Mon Mar 15, 2010 12:14 PM
I tried version 1.3e but it didn't work for me as well...
F.
F.
-John
Oh my, everything is OK under version 1.2! Thanks for help!
F.
#5
Posted Tue Mar 16, 2010 12:24 AM
I've had weird errors like this happen when the files
Prosystem.dat
Prosystem.chm
are missing. I had this happen when compiling from source.
These need to be in the same folder with the executable.
ProSystem13e_chm_dat.zip 300.12K
20 downloads
I tried 1.3e with those files removed, and it caused the same errors you described with Ikari and MM.
That's very true. 1.3d is seriously bugged in the way it toggles between 1 and 2 button mode. Nobody should run that version - several games are broken on that version, because they boot in the wrong mode or switch improperly. 1.3e does it correctly.
Prosystem.dat
Prosystem.chm
20 downloadsI tried 1.3e with those files removed, and it caused the same errors you described with Ikari and MM.
Quote
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
