adamantyr also suggested adjustment of octaves to fit the TI, which is a great idea.
I previously saw 4 different styles of input, namely “event”, “tracker”, “matrix” and “score”. I’m now trying out a piano style approach with editing basically on the “keys”. A small control board with play, stop, rewind and stepping. This is often how you would do editing on a synthesizer (small display so one note/chord at a time), though I guess any “sane” person would edit using PC software.
“Event”, “tracker” and “matrix” could be done on the TI too. Trying to do “score” on the TI seems like a major project.
Well, the suggested “key” approach would be quite plausible on both the TI and in some lightweight Flash solution. I’ll start work on those.
The “key” solution would probably mostly be a convenient way to enter music, but you could do a bit of composing too. If you want to go from music sheet to TI, and don’t know how to read music sheets, then there is free software out there to show you the keys (like C#1 and A2 or which key on the piano).
Output would be TI internal eventlist and XB data statements.
