as usual I'm sharing our (MaPa & PG) newest 1kB intro called Scroll F'ever for anyone interested. In the attached ZIP file you will find all the necessary files to successfully compile the main source file scroll.xsm (with XASM assembler which I used) to working executable. On top there is compiled executable scroll.xex and compressed one Scroll F'ever.xex which is about 40% smaller and was used as the compo entry. As usual it works correctly only in PAL, NTSC doesn't have enough time in one frame. Also there is source file scroll_chngcol.xsm and its corresponding .xex file which was made to test some different color schemes. In the upper part of the screen is displayed color register C0-C8 which means $2c0-$2c8 end next to it its corresponding color value. You can play with the colors with keys Q and A (changing color register), W and S (changing hue of selected register), E and D (changing luma). We hope you like our intro so enjoy it!
Edited by MaPa, Mon Mar 22, 2010 4:28 AM.
