0
What am I doing wrong with skipdraw
4 replies to this topic
#1 yllawwally OFFLINE
yllawwally
    Star Raider
  • 59 posts
Posted Fri Apr 2, 2010 5:08 PM
I tried to adapt this code to use skipdraw. However the graphics are not correct. The sprite starts in the correct location, however it seems to scroll through the memory, until you're on a certain y position. Then the graphics continue to the bottom of the screen. My code is below.
	processor 6502
	include vcs.h
	org $F000
;Variables ------
YPosFromBot = $80;
VisiblePlayerLine = $81;
PICS = $82;
ROLLING_COUNTER = $83;
Graphics_Buffer = $84
YPosFromBotE1 = $85;
VisibleEnemyLine = $86;
VisibleEnemyLineCurrent = $87;
EnemyLineBuffer = $88;
VisiblePlayerLineCurrent = $90;
BG_0 = $91;
BG_1 = $92;
BG_2 = $93;
; Constants ------
playerheight      ds #8;
;generic start up stuff...
Start
	SEI
	CLD
	LDX #$FF
	TXS
	LDA #0
	STA ROLLING_COUNTER
	STA PICS
	STA EnemyLineBuffer
ClearMem
	STA 0,X
	DEX
	BNE ClearMem
	LDA #$00   ;start with a black background
	STA COLUBK
	LDA #$1C   ;lets go for bright yellow, the traditional color for happyfaces
	STA COLUP0
;Setting some variables...
	LDA #80
	STA YPosFromBot	;Initial Y Position
	STA YPosFromBotE1
	LDA #010001		; 2 cycles
	STA BG_0		; 3 cycles
	STA BG_1		; 3 cycles
	STA BG_2		; 3 cycles
;; Let's set up the sweeping line. as Missile 1
	LDA #2
;	STA ENAM1  ;enable it
	LDA #33
	STA COLUP0 ;color it
	STA COLUP1 ;color it
	LDA #$10
;	STA NUSIZ0	;make it quadwidth (not so thin, that)
	STA NUSIZ1	;make it quadwidth (not so thin, that)
	LDA #000000	; set to not move
	STA HMM1	; of HMM1 sets it to moving
;VSYNC time
MainLoop ;+++++++++++++++++++++++++++The start of a new screen
	LDA #0
	STA GRP0
	STA GRP1
	STA PF0
	STA PF1
	STA PF2
	LDA #2
	STA VSYNC
	STA WSYNC
; for up and down, we INC or DEC
; the Y Position
	LDA #010000	;Down?
	BIT SWCHA
	BNE SkipMoveDown
	INC YPosFromBot
	INC YPosFromBotE1
	INC YPosFromBotE1
SkipMoveDown
	LDA #100000	;Up?
	BIT SWCHA
	BNE SkipMoveUp
	DEC YPosFromBot
	DEC YPosFromBotE1
	DEC YPosFromBotE1
SkipMoveUp
; for left and right, we're gonna
; set the horizontal speed, and then do
; a single HMOVE.  We'll use X to hold the
; horizontal speed, then store it in the
; appropriate register
;assum horiz speed will be zero
	LDX #0
	LDA #%01000000	;Left?
	BIT SWCHA
	BNE SkipMoveLeft
	LDX #$10	;a 1 in the left nibble means go left
;; moving left, so we need the mirror image
	LDA #001000   ;a 1 in D3 of REFP0 says make it mirror
	STA REFP0
	STA REFP1
SkipMoveLeft
	LDA #%10000000	;Right?
	BIT SWCHA
	BNE SkipMoveRight
	LDX #$F0	;a -1 in the left nibble means go right...
;; moving right, cancel any mirrorimage
	LDA #000000
	STA REFP0
	STA REFP1
SkipMoveRight
	STX HMP0	;set the move for player 0, not the missile like last time...
	STX HMP1	;set the move for player 0, not the missile like last time...
; see if player and missile collide, and change the background color if so
	;just a review...comparisons of numbers always seem a little backwards to me,
	;since it's easier to load up the accumulator with the test value, and then
	;compare that value to what's in the register we're interested.
	;in this case, we want to see if D7 of CXM1P (meaning Player 0 hit
	; missile 1) is on. So we put 10000000 into the Accumulator,
	;then use BIT to compare it to the value in CXM1P
	LDA #%10000000
	BIT CXM1P
	BEQ NoCollision	;skip if not hitting...
	LDA YPosFromBot	;must be a hit! load in the YPos...
	STA COLUBK	;and store as the bgcolor
NoCollision
	STA CXCLR	;reset the collision detection for next time
	STA WSYNC ;//////////////////////////////////////////////
;setup pic animations ----------------------------------------------
	INC ROLLING_COUNTER
	LDA ROLLING_COUNTER
	AND #15		;every 8th screen swap to next image of player
	CMP #8
	BEQ PICSET4
	JMP PICSET3
PICSET4	LDA  PICS
	CMP  #8
	BEQ PICSET
	LDA  #8
	JMP PICSET2
PICSET	LDA  #0
PICSET2	STA PICS
PICSET3
	LDA ROLLING_COUNTER
	AND #25		;how often to move enemy, larger number is slower
	CMP #8
	BEQ PICSET5
	LDA #001111	; +1 in the left nibble
	JMP PICSET6
PICSET5	LDA #011111	; 0 in the left nibble
PICSET6	STA HMP1	; of HMP1 sets it to moving the enemy
	LDA #8
	CLC
	ADC PICS	;add value of pics to Accumulator
	STA VisibleEnemyLineCurrent
	LDA #8
	CLC
	STA VisiblePlayerLineCurrent
	LDA #43
	STA TIM64T
	LDA #0
	STA VSYNC
;------------------------- setup backgrounds 20 pixels accross
	LDA #255			; 3 cycles
	STA PF0			; 3 cycles
	STA PF1			; 3 cycles
	STA PF2			; 3 cycles
WaitForVblankEnd
	LDA INTIM
	BNE WaitForVblankEnd
	LDY #4 ; was 191
	STA WSYNC
	STA HMOVE
	STA VBLANK
;main scanline loop...
PreScanLoop
ScanLoop1 ;start of kernal +++++++++++++++++++++++ for skyline
	LDA PFCOLOR-1,Y		; 4 cycles
	STA COLUBK	;and store as the bgcolor ; 3 cycles
	LDA PFData0-1,Y		; 4 cycles
	STA PF0			; 3 cycles
	LDA PFData1-1,Y		; 4 cycles
	STA RESM0		; 3 cycles places left scan line leftmost
	STA PF1			; 3 cycles
	LDA PFData2-1,Y		; 4 cycles
	STA PF2			; 3 cycles
	LDA #0							;2 cycles =30
	STA GRP1	; put player 1 into grp1 3 cycles
	STA GRP0	;put that line as player graphic 0	 ;3 cycles =28
	DEY		;count down number of scan lines	  2 cycles =71
	STA WSYNC 						 ;3 cycles =74
	BNE ScanLoop1		 				 ;2 cycles =76
EndScanLoop1 ;end of kernal +++++++++++++++++++++++ for skyline
	LDA #100;
	LDY #186 ; was 191 was 186
	LDA #0
	STA PF0			; 3 cycles
	STA PF1			; 3 cycles
	STA PF2			; 3 cycles
	LDA #%11100011	;The last 3 bits control number and size of players
			;the firs 3 bits control missle size
	STA NUSIZ0
	STA NUSIZ1
	STA WSYNC 						 ;3 cycles
ScanLoop ;start of kernal +++++++++++++++++++++++ for players
        ;-------------------------- y register is the line number currently being drawn
        ; SPRITE DRAW
        tya                     ; 2 Transfers the byte in the Y Register to the Accumulator.
        sec                     ; 2 Sets the carry (C) flag (in the processor Status Register byte).
        sbc YPosFromBot         ; 3 Subtracts a byte in memory from the byte in the Accumulator, and "borrows" if necessary.
        adc #8      		; 2 Adds byte in memory to the byte in the Accumulator, plus the carry flag if set.
        bcs .Draw               ; 2(3) Branches up to 127 bytes forward or 128 bytes backward from its own address if the carry flag is set.
        nop                     ; 2 Wait
        nop                     ; 2 Wait
        bcs .skipDraw           ; 3 Branches up to 127 bytes forward or 128 bytes backward from its own address if the carry flag is set.
.Draw
        lda MainPlayerGraphics,y          ; 5 Loads the Accumulator with a byte from memory.
        sta GRP0	          ; 3 Stores the byte in the Accumulator into memory.
.skipDraw
         ;-->18 cycles used
;	STA GRP0  	;set player graphics                                  3 cycles
;	STA GRP1  	;set player graphics                                  3 cycles
	BNE ScanLoop		 				 ;2 cycles =
EndScanLoop ;end of kernal +++++++++++++++++ for players
	STA WSYNC
	STA VBLANK
	LDX #24
OverScanWait
	STA WSYNC
	DEX
	BNE OverScanWait
	JMP  MainLoop
MainPlayerGraphics
	.byte #010100
	.byte #010100
	.byte #011000
	.byte #011000
	.byte #%01111110
	.byte #010000
	.byte #111000
	.byte #111000
SpriteEnd
	.byte #100010
	.byte #100100
	.byte #101000
	.byte #011000
	.byte #%01111110
	.byte #010000
	.byte #111000
	.byte #111000
EnemyGraphics
	.byte #%01111000
	.byte #%10000100
	.byte #001000
	.byte #010000
	.byte #010000
	.byte #010000
	.byte #111000
	.byte #111000
	.byte #%01111000
	.byte #%01001000
	.byte #010000
	.byte #100000
	.byte #100000
	.byte #100000
	.byte #%01110000
	.byte #%01110000
PFData0
        .byte #001111
        .byte #011111
        .byte #%01111111
        .byte #%11111111
PFData1
        .byte #000000
        .byte #001110
        .byte #111111
        .byte #%01111111
PFData2
        .byte #000000
        .byte #011000
        .byte #%10111100
        .byte #%11111111
PFCOLOR
	.byte #$5F
	.byte #$5D
	.byte #$5B
	.byte #$59
	org $FFFC
	.word Start
	.word Start
#2 johnon OFFLINE
johnon
    Chopper Commander
  • 241 posts
  • Aspiring 2600 Developer
Posted Fri Apr 2, 2010 5:37 PM
Well, for starters, I'm not sure your graphics are handled correctly. There are a lot of missing % signs in there and I've never seen graphics handled in decimal numbers (usually binary, though in the case of Adventure, hexadecimal), nor have I ever seen any decimal numbers as big as 10000 used in anything Atari VCS. Coupled with the fact that there are zeros in front of those decimal numbers (not needed, as by rules of basic mathematics), this leads me to believe that your issue is that you have, in fact, accidentally messed up some numbers and the VCS is reading it a little oddly. Remember, it won't correct your mistakes. ;)
If this is, in fact, the issue, it's an easy fix. See if that works. Otherwise, I can't help you, as my knowledge of VCS coding is minimal at this point.
I only say this is the issue, as any number of odd things could happen when you make the smallest mistake. Once, after trying to incorporate editing playfield and background graphics in the same timer, I ended up changing my playfield from white to purple and activating a constant stream of audio without ever knowing what I did wrong.
However, I could always be really off. As I've said, I haven't worked with the system long. :D
Edited by johnon, Fri Apr 2, 2010 5:57 PM.
#3 yllawwally OFFLINE
yllawwally
    Star Raider
  • 59 posts
Posted Mon Apr 5, 2010 12:12 PM
I don't know what happened to the graphics info. In the original source, it's all in binary. Something about pasting it here, damaged it.
	processor 6502
	include vcs.h
	org $F000
;Variables ------
YPosFromBot = $80;
PICS = $82;
BG_0 = $91;
BG_1 = $92;
BG_2 = $93;
; Constants ------
playerheight      ds #8;
Start
	SEI
	CLD
	LDX #$FF
	TXS
	LDA #0
	STA ROLLING_COUNTER
	STA PICS
	STA EnemyLineBuffer
ClearMem
	STA 0,X
	DEX
	BNE ClearMem
	STA COLUBK
	STA COLUP0
	LDA #80
	STA YPosFromBotE1
	STA BG_0		; 3 cycles
	STA BG_1		; 3 cycles
	STA BG_2		; 3 cycles
	LDA #2
	LDA #33
	LDA #$10
;VSYNC time
	LDA #0
	STA GRP0
	STA GRP1
	STA PF0
	STA PF1
	STA PF2
	LDA #2
	STA VSYNC
	STA WSYNC
; the Y Position
	LDA #010000	;Down?
	BIT SWCHA
	BNE SkipMoveDown
	INC YPosFromBot
	INC YPosFromBotE1
	INC YPosFromBotE1
SkipMoveDown
	LDA #100000	;Up?
	BIT SWCHA
	BNE SkipMoveUp
	DEC YPosFromBot
	DEC YPosFromBotE1
	DEC YPosFromBotE1
SkipMoveUp
	LDX #0
	BIT SWCHA
	BNE SkipMoveLeft
	STA REFP0
	STA REFP1
SkipMoveLeft
	BIT SWCHA
	BNE SkipMoveRight
	LDA #000000
	STA REFP0
	STA REFP1
SkipMoveRight
	LDA #%10000000
	BIT CXM1P
NoCollision
	INC ROLLING_COUNTER
	LDA ROLLING_COUNTER
	CMP #8
	BEQ PICSET4
	JMP PICSET3
PICSET4	LDA  PICS
	CMP  #8
	BEQ PICSET
	LDA  #8
	JMP PICSET2
PICSET	LDA  #0
PICSET2	STA PICS
PICSET3
	LDA ROLLING_COUNTER
	CMP #8
	BEQ PICSET5
	JMP PICSET6
	LDA #8
	CLC
	LDA #8
	CLC
	LDA #43
	STA TIM64T
	LDA #0
	STA VSYNC
	LDA #255			; 3 cycles
	STA PF0			; 3 cycles
	STA PF1			; 3 cycles
	STA PF2			; 3 cycles
WaitForVblankEnd
	LDA INTIM
	LDY #4 ; was 191
	STA WSYNC
	STA HMOVE
	STA VBLANK
PreScanLoop
	STA PF0			; 3 cycles
	STA PF1			; 3 cycles
	STA PF2			; 3 cycles
	LDA #100;
	LDA #0
	STA PF0			; 3 cycles
	STA PF1			; 3 cycles
	STA PF2			; 3 cycles
	STA NUSIZ0
	STA NUSIZ1
	STA WSYNC 						 ;3 cycles
        ; SPRITE DRAW
        nop                     ; 2 Wait
        nop                     ; 2 Wait
.Draw
.skipDraw
         ;-->18 cycles used
skipDrawRight        ; 3 from BCC
   LDA #0            ; 2
   BEQ continueRight ; 3 Return...
   TXA                          ; 2 A-> Current scannline
   SEC                          ; 2 Set Carry
   SBC YPosFromBot 		; 3
   ADC #8          		; 2 calc if sprite is drawn
   BCC skipDrawRight            ; 2/3 To skip or not to skip?
   TAY                          ; 2
   lda P1Graphic,y              ; 4
continueRight:
   STA GRP0
	STA WSYNC
	STA VBLANK
	LDX #24
OverScanWait
	STA WSYNC
	DEX
	BNE OverScanWait
	JMP  MainLoop
MainPlayerGraphics
	.byte #010100
	.byte #010100
	.byte #011000
	.byte #011000
	.byte #%01111110
	.byte #010000
	.byte #111000
	.byte #111000
SpriteEnd
	.byte #100010
	.byte #100100
	.byte #101000
	.byte #011000
	.byte #%01111110
	.byte #010000
	.byte #111000
	.byte #111000
EnemyGraphics
	.byte #%01111000
	.byte #%10000100
	.byte #001000
	.byte #010000
	.byte #010000
	.byte #010000
	.byte #111000
	.byte #111000
	.byte #%01111000
	.byte #%01001000
	.byte #010000
	.byte #100000
	.byte #100000
	.byte #100000
	.byte #%01110000
	.byte #%01110000
PFData0
        .byte #001111
        .byte #011111
        .byte #%01111111
        .byte #%11111111
PFData1
        .byte #000000
        .byte #001110
        .byte #111111
        .byte #%01111111
PFData2
        .byte #000000
        .byte #011000
        .byte #%10111100
        .byte #%11111111
PFCOLOR
	.byte #$5F
	.byte #$5D
	.byte #$5B
	.byte #$59
	org $FFFC
	.word Start
	.word Start
#4 yllawwally OFFLINE
yllawwally
    Star Raider
  • 59 posts
Posted Mon Apr 5, 2010 12:15 PM
OK I'll just insert a file. Apparently paste doesn't like, binary numbers? And the uploader doesn't like .asm files.
#5 Omegamatrix OFFLINE
Omegamatrix
  • 4,795 posts
Posted Mon Apr 5, 2010 1:47 PM
The forum software is gobbling up % signs followed by a 0. This bug has been reported though.
I usually just take the .asm file and zip it before posting. That's what most other people seem to do too.
