Atari Lynx Screen problem!
6 replies to this topic
#1 Nerdy OFFLINE
Nerdy
    Combat Commando
  • 2 posts
Posted Sun Apr 18, 2010 9:47 AM
Hello guys, i bought an atari lynx this morning on a car boot sale where i live, when i came home and tried the system, the screen seems a lil fuzzy and with some black lines
Posted Image
Unfortunatly im not very familiar with atari hardware so im kinda clueless, if you guys can help me with i fix i would really apreciate it :)
Im okay with repairs, soldering and etc :)
#2 chris_lynx1989 OFFLINE
chris_lynx1989
    Dragonstomper
  • 785 posts
  • Cool,isn't it?
Posted Sun Apr 18, 2010 10:36 PM
Have you cleaned your cart or port?The only other thing could be your screen ribbon has slipped a little out of it's socket or your LCD has a leak and is failing.Also,were you using it close to a microwave or other high RF/magnetic interference source?The lines do remind me of LCD panel failure,just haven't had it on a Lynx like that.I have had an LCD ribbon age crack through and fail though,could be your case too. :) :( If so,that's a $25+ problem for you,the last I knew. :(
#3 Nerdy OFFLINE
Nerdy
    Combat Commando
  • 2 posts
Posted Mon Apr 19, 2010 1:19 PM
Already cleaned the cart's and the port, and its stil the same, checked the LCD for any damage or leak, and nothing, seems mint. any idea? I really would love to repair this baby, got it so cheap :/
#4 chris_lynx1989 OFFLINE
chris_lynx1989
    Dragonstomper
  • 785 posts
  • Cool,isn't it?
Posted Tue Apr 20, 2010 12:24 AM
Did you try to reseat your LCD ribbon to socket?If not,you loosen the tension clip on each side carefully to remove/install ribbon.Pull out/push in gently as a slight thump will be felt/heard each time.If not that,it is your LCD leaking probably.If you or a friend have a "Lynx Diagnostic Cart" you would know if there is a problem elsewhere too with Mikey or Suzy or etc.They are a neat item,I've had one since 1997. :) It does like 6 tests on a Lynx.If you need a LCD or cart,Brad has both.Let me know
#5 jaguar_fan OFFLINE
jaguar_fan
    Dragonstomper
  • 542 posts
Posted Tue Apr 20, 2010 12:50 AM
Looks like a LCD ribbon cable issue to me. Removing and reseating the cable should probably help.
#6 chris_lynx1989 OFFLINE
chris_lynx1989
    Dragonstomper
  • 785 posts
  • Cool,isn't it?
Posted Wed Apr 21, 2010 3:08 AM
The only thing is,when I had my ribbon slip I had vertical white bands or a blank white screen.It's why I said a LDC might be of help too.The screen reminds of an LCD leak and failure also.It isn't a ribbon crack they say.
#7 BillyHW ONLINE
BillyHW
    Dragonstomper
  • 733 posts
Posted Sun Jan 22, 2012 1:01 AM
Gameboys used to do this a lot, but with vertical lines.
