0
Dead 5200...Is this thing fixable?
8 replies to this topic
#1 Atarius Maximus OFFLINE
Atarius Maximus
  • 1,064 posts
  • Load "Atari2600",8,1: SYS32777
Posted Wed Nov 20, 2002 11:28 AM
I received a 4 port 5200 a few months ago in a large game lot that doesn't seem to work. The LED light doesn't come on when you hit the power switch, and I don't get a picture on the screen. I know the power supply is OK, because it's the same one I use with my working 2-port 5200.
I don't know where to begin to troubleshoot this one. Could it be the Atari Switch box that's bad? I only have one, so I can't test with a different one. Does anyone have any suggestions, or should I just use this thing as a boat anchor?
AM
#2 CPUWIZ OFFLINE
CPUWIZ
    Rarity 11
  • 26,327 posts
  • Cartridge Recycler
Posted Wed Nov 20, 2002 1:35 PM
I am not sure if the 2 port PSU will work on a 4 port, mine has a higher voltage rating. My 2 port PSU is rated 9V and the 4 port is 11.5V but I have never tried using the 2 port PSU on the 4 port. I guess I could try and let you know.
#3 voiddweller OFFLINE
voiddweller
    Moonsweeper
  • 255 posts
Posted Wed Nov 20, 2002 1:36 PM
Hi,
The switchbox is very likely. You can get a new one at Best-Electronics for $12 to test it out (you could always re-sell it to get your money back) or I'm sure someone with more technical knowledge than me has a way to test it without the new box. One obvious thing you may want to check is burnt connections on the MOBO. I've seen a few 5200's that were the victim of lightning strikes.
- VD
#4 voiddweller OFFLINE
voiddweller
    Moonsweeper
  • 255 posts
Posted Wed Nov 20, 2002 1:38 PM
Hi,
I've used the 9V on my 4 Port and it worked fine.
- VD
#5 Mitch OFFLINE
Mitch
  • 5,768 posts
  • 7800 Guy
Posted Wed Nov 20, 2002 2:41 PM
All three of the 5200 power supplies are interchangable. :)
Mitch
http://atari7800.atari.org
#6 King Atari OFFLINE
King Atari
  • 5,236 posts
Posted Wed Nov 20, 2002 3:21 PM
Quote
Yikes. These things so big they act as lighting rods :D ?
#7 voiddweller OFFLINE
voiddweller
    Moonsweeper
  • 255 posts
Posted Wed Nov 20, 2002 3:51 PM
Yeah,
This was about 8 years ago, but the story goes:
I found three 5200 2 Port models at a yard sale. All in excellent condition on the outside...boxes and everything...then I opened them up when they wouldn't turn on and...well....BAM! :D I realized all three were hit by lightning. :( What are the odds for three Atari bricks at one yard sale???
- VD
#8 Atarius Maximus OFFLINE
Atarius Maximus
  • 1,064 posts
Posted Wed Nov 20, 2002 5:01 PM
Yeah, I guess I'll have to buy another switch box to test this problem. Before I do that, I'll take your advice and inspect the MOBO for any obvious problems.
I didn't receive a PSU with the 4-port, I just assumed they were the same. If the 2 port is 9v and the 4 port is 11.5v, maybe the fact that it's getting 2.5 less volts is the problem? Then again, according to Mitch they're interchangable. :? If you have time to test it on your systems, let me know what happens.
Thanks for the replies.
AM
#9 voiddweller OFFLINE
voiddweller
    Moonsweeper
  • 255 posts
Posted Wed Nov 20, 2002 8:14 PM
Quote
...  Then again, according to Mitch they're interchangable....AM
Mitch is correct, they are interchangable.
- VD
