5-11under, on Sat Aug 14, 2010 11:45 AM, said:
Video, on Sat Aug 14, 2010 11:34 AM, said:
I'd get the lowest voltage possible, just honestly, unless your trying to light up a room or something, it doesn't need a lot of power.
Other than that, you just need to wire he LED to the 5v in on the card edge, and the other end to the ground, which should light it up when the system is powered up, though I don't knwo if you'll get enough power to still run the rom in the process (assuming you want to)
Don't forget a series resistor! Time for some Google-ing.
5--1under
Yeah, LEDs don't work on voltage, they work on current. If you hook up an LED to a power source, it will try to pass all the current the power source will give it, even if that causes the voltage to zero-out, all the while going nuclear-bright like a tiny sun.
That is, until it burns itself out. Unless the circuit already provides current-limiting, you always need a resistor in series with the LED.
yuppicide, just look up the specs of the LED you want on Digi-Key or Mouser. LEDs run the gamut from just a few mA up to 10 or 20mA, depending on type and how bright you want it (how much resistance you pair it with). IIRC, blue and white LEDs generally take more current than the older red, green and yellow LEDs for the same light output.
-tet
Edited by tetrode kink, Wed Aug 18, 2010 1:05 AM.
