0
2-PORT 5200 CAN BE CONNECTED W/STANDARD CONNECTOR; PLZ VERIF
16 replies to this topic
#1 marty_rules2001 OFFLINE
marty_rules2001
    Space Invader
  • 19 posts
Posted Mon Nov 25, 2002 12:53 PM
:? Help!
I have an Atari 2600, 5200 & 7800. The 5200 is a two-port system. I was under the impression that this system can be hooked up to the TV via the connector box used for the 2600 & 7800. However, when I did it, I started to play Pacman and about half way through the first board the screen went fuzzy and then to complete snow. I thought I toasted my switchbox but after I hooked the 7800 back up, that system worked fine. To ensure I didn't toast the 5200, I hooked it up again and only turned the system on to make sure it was still sending a signal. It was as the startup screen for the game displayed. I turned it off and wondered if I need to get my hands on the four-port connector box.
Any suggestions?
Marty
#2 NoahsMyBro OFFLINE
NoahsMyBro
    Dragonstomper
  • 547 posts
Posted Mon Nov 25, 2002 1:12 PM
Well, I can't say what the problem IS, but I can tell you that the 2 port 5200 will work just fine with the switchbox used for the 2600 & 7800, and that is not your problem.
#3 Cafeman ONLINE
Cafeman
  • 4,282 posts
  • North of 40
Posted Mon Nov 25, 2002 1:35 PM
I use the exact same Radio Shack RF unit for 2600, 7800, and Intellivision -- works fine. If you have an old RF, maybe splurge and buy a new one at Radio Shack? they are under $10 I'm pretty sure.
#4 marty_rules2001 OFFLINE
marty_rules2001
    Space Invader
  • 19 posts
Posted Mon Nov 25, 2002 2:07 PM
Cafeman,
I did just that over the weekend! It's brand new and I don't want to run the risk of burning it up (if that can even be done) and then not be able to use any of the three systems. The only thing I can think of is I have two power supplies - one from a 4-port system and one from the 2-port system. I don't know if that could have an affect or not, but I thought I'd mention it.
Marty
#5 Cafeman ONLINE
Cafeman
  • 4,282 posts
  • North of 40
Posted Mon Nov 25, 2002 2:18 PM
You should use the 2-port power supply with the 2-port system, then run the 2-port's wired-in TV cable into the GAME part of the RF.
Are you sure the 5200 is set for the correct channel?
I've never heard of an RF getting burned up. Not sure that's possible.
The 4-port 5200 has its on RF, in which the power plugs directly into this unique RF itself. You shouldn't be using any of this for a 2-port system.
#6 Mitch OFFLINE
Mitch
  • 5,768 posts
  • 7800 Guy
Posted Mon Nov 25, 2002 2:41 PM
The RF switchbox for the 2 port is identical to the 2600 and 7800 switchbox, as the other guys have said. The 5200 power supplies are interchangable, it doesn't matter if it came with a 2 port or 4 port.
I think the most likely cause of the problem is a failing chip in the 2 port 5200. It's hard to say for sure without seeing the unit. Good luck.
Mitch
http://atari7800.atari.org
#7 Allan OFFLINE
Allan
  • 4,245 posts
Posted Mon Nov 25, 2002 2:44 PM
Isn't the two-port and the four-port power supply the same part? I didn't think there was any difference.
Allan
#8 voiddweller OFFLINE
voiddweller
    Moonsweeper
  • 255 posts
Posted Mon Nov 25, 2002 2:49 PM
Hi,
I'm pretty sure they are interchangeable.
- VD
#9 marty_rules2001 OFFLINE
marty_rules2001
    Space Invader
  • 19 posts
Posted Mon Nov 25, 2002 2:50 PM
Cafeman,
Back up a little!
1. How do I determine the difference between the 4-port and 2-port power supplies?
2. How do I determine if the 5200 is set for the correct channel? Is that the circle-and-box switch on the back? If so, which setting should I use? Could this contribute to it coming up, working for a few and then quickly fading to snow???
Marty
#10 Cafeman ONLINE
Cafeman
  • 4,282 posts
  • North of 40
Posted Mon Nov 25, 2002 2:56 PM
Okay, first ignore what I said about the power supply, I've been corrected by everyone -- they are the same (news to me!).
I am not looking at the 5200 right now, but isn't there a little switch where you select either channel 2 or 3 (or is it 3 or 4? one of those)? If you are using Channel 3 on the TV, you have to set it to channel 3 on the 5200, right? It's been a long time since I messed with these things.
It sounds like something is wrong with either your 5200 cable(s) or the system itself though. Does jiggling the 5200's cable (the one that goes into the RF) seem to improve or even affect the picture?
#11 marty_rules2001 OFFLINE
marty_rules2001
    Space Invader
  • 19 posts
Posted Mon Nov 25, 2002 3:06 PM
Cafeman,
That's just it - I connected it and turned it on and it came up fine. Then while playing (after only 5 minutes??) the screen started to fade to static and then went to complete static - all in about 5 seconds so it's not like the signal just up and died like it was disconnected. I also re-connected it after testing the 2600 & 7800 systems and it came back up but I didn't want to press my luck and possibly do damage to it or the rf box.
Marty
#12 sku_u OFFLINE
sku_u
  • 13,984 posts
Posted Mon Nov 25, 2002 3:13 PM
I had a similar problem with my old atari 2600. On my system at least, it turned out that the RF CONNECTOR itself was causing the problem. I spliced on a new one and the system worked fine again. Have you checked the wire that goes from your system to the switchbox for any cuts? That can also affect the image you see on the television.
#13 marty_rules2001 OFFLINE
marty_rules2001
    Space Invader
  • 19 posts
Posted Mon Nov 25, 2002 3:16 PM
No, no problems with the cables or the rf box. The box, in fact, is brand new - just bought one from Radio Shack (which, by the way, the manager said they will no longer be carrying so if you need one, get it NOW).
#14 sku_u OFFLINE
sku_u
  • 13,984 posts
Posted Mon Nov 25, 2002 3:36 PM
Not the box, the male connector that actually plugs into the box. I have a few of those Radioshack boxes. They do not always work that well. I have one of the coxial plugs featured here:
http://www.atariage....e/Hardware.html
I get a much better image on the television through this. Although I couldn't get the plug to work with my 2600 for some reason. :(
#15 marty_rules2001 OFFLINE
marty_rules2001
    Space Invader
  • 19 posts
Posted Mon Nov 25, 2002 3:41 PM
The cables are in good shape as well. That rf adapter - can I get it at Radio Shack (on my way home :) ) or do I need to order it from the webpage??
#16 sku_u OFFLINE
sku_u
  • 13,984 posts
Posted Mon Nov 25, 2002 4:13 PM
I was just at Radio Shack a few minutes ago. I was looking for an extra F-Coax adaptor. They didn't have it at the one I went to at least.
#17 yodan OFFLINE
yodan
    Chopper Commander
  • 209 posts
Posted Fri Nov 29, 2002 3:32 PM
I highly recommend the Coaxial (F-Type) to Female RCA Adapter. I bought a 3-input coax switch and three of the adapters and now I never have to deal with tv/game switches. IMO your problem sounds like a power supply issue.
