0
Atari 2600 IDE in Linux?
3 replies to this topic
#1 PSW OFFLINE
PSW
    Space Invader
  • 33 posts
Posted Thu Sep 9, 2010 5:01 PM
I ran across the following website that describes how to set up a "pseudo"-IDE for VCS programming using Scite, DASM, and Stella.
VCS IDE Setup
The author of the article can compile from within Scite by setting up Scite's .asm properties with a batch file. Does anyone know how to do the same thing in a linux environment? Better yet, if you have a "better" linux setup, please provide information not only on what programs you are running, but how you set them up as an IDE. I'm a noob, so the more detailed you are with your explanation, the better. FYI, I'm using Ubuntu 8.04LTS on a laptop, and 10.04LTS on a desktop.
#2 RevEng OFFLINE
RevEng
  • 2,010 posts
  • bit shoveler
Posted Thu Sep 9, 2010 6:05 PM
Not exactly what you're asking for, but I create a Makefile and let the command-line be my IDE.
The present version of my Makefile handles the following commands:
    make #assembles the project if the files have changed
    make verbose #assembles the project with dasm verbosity set to 5
    make run #launches the project in stella
    make debug #launches the project in stella, starting in the debugger
    make test #copies the .bin to the SD card I use in Harmony
    make clean #removes .bin and intermediate files
    make backup #creates a tarball of the directory and mails it to a gmail account
Definitely recommended if you're comfortable with a command-line!
#3 PSW OFFLINE
PSW
    Space Invader
  • 33 posts
Posted Thu Sep 9, 2010 6:44 PM
Thanks, but I'm looking for something more GUI oriented, as I am not too savy with the command line.
#4 ZagNut OFFLINE
ZagNut
    Combat Commando
  • 1 posts
Posted Sat Oct 9, 2010 1:32 PM
Greetings!
This is the author of said website. I've just put up a post re: this issue. I made a script that will set up the SciTE, Stella, DASM setup I'm using on my Win 7 machine on an Ubuntu setup. It may work for other Linux installs.
Anyway, the post is here. It will download and install everything for you. Just launch it as follows:
sudo script-filename $USER
Cheers,
~ZagNut
