halo on the harmony cart
5 replies to this topic
#1 flammingcowz ONLINE
flammingcowz
    Moonsweeper
  • 434 posts
Posted Thu Oct 28, 2010 1:18 AM
I saw halo posted for free so I tried playing it on the harmony cart, and beat it. Then I read the thread and saw the creators posts and that he had made it so the walls and trees don't kill you, which they did do on the harmony cart. So I played the same rom on Stella and the trees/walls didn't hurt you at all.
Also, after beating it I got stuck in the boss room again but the screen was rolling, none of which happened on Stella.
Anyone else notice these problems? Will an older version of the harmony software fix it?(im on the newest)
thanks
edit: On stella grabbing a shield makes you flash, which I don't think happened on the harmony but I could be wrong.
Edited by flammingcowz, Thu Oct 28, 2010 1:21 AM.
#2 Thomas Jentzsch OFFLINE
Thomas Jentzsch
    Thrust, Jammed, SWOOPS!
  • 16,745 posts
  • Always left from right here!
Posted Thu Oct 28, 2010 4:46 AM
I am 100% sure, that's not a Harmony cart problem.
1. There is a configuration when the trees and walls become deadly.
2. Stella doesn't emulate screen rolls at all. If it rolls with Harmony, it would roll with a real cart too
3. I see the shield flash with my Harmony cart
#3 flammingcowz ONLINE
flammingcowz
    Moonsweeper
  • 434 posts
Posted Thu Oct 28, 2010 11:40 AM
wow i cant believe I didn't think of the obvious answer, thanks
#4 pimpmaul69 OFFLINE
pimpmaul69
    Moonsweeper
  • 411 posts
  • Crazy Mad Modder
Posted Tue Sep 13, 2011 10:17 PM
are you using an av mod? i use the ben heck mod that is based on the longhorn engineers, but i use 1k pots and adjust them myself. the best carts i used to get best image was the starpath frogger and donkey kong.if you dont have the scrolling colors on the harmony meny then you will probably have the shields flashing. the shields used to flash until i fixed the color after playing the official frogger,then playing donkey kong to make final touch up with the color adjustment.
#5 pimpmaul69 OFFLINE
pimpmaul69
    Moonsweeper
  • 411 posts
  • Crazy Mad Modder
Posted Wed Sep 14, 2011 12:10 AM
nm what i said. what i said refers to flashing shield. yes your guy flashes on the harmony.
#6 snstay OFFLINE
snstay
    Chopper Commander
  • 181 posts
  • "I know what willis is talkin about"
Posted Sun Sep 18, 2011 7:53 PM
I just downloaded halo and put it on the harmony. It seems to work fine!
