Fixing a pinball machine
7 replies to this topic
#1 MichaelJMcKernan OFFLINE
MichaelJMcKernan
    Moonsweeper
  • 440 posts
Posted Fri Oct 29, 2010 2:36 PM
I have been entrusted with trying to find a way to fix this thing.
It was my deceased father's, was left at a brother's house...
He tried to repair it, and it has come out recently that the repairman stole the motor.
http://www.marvin3m....eball/dlx54.htm
I'm not the most handy fellow, and was wondering if anyone could give me a jumping off point?
Thanks. First post in many years!
#2 Videogamecollector123 OFFLINE
    Moonsweeper
  • 348 posts
Posted Sun Oct 31, 2010 7:36 AM
Could you list all the problems it has? I guess the obvious one would be if it powers on at all, then what functions work and don't work.
#3 save2600 ONLINE
save2600
  • 5,805 posts
Posted Sun Oct 31, 2010 7:41 AM
You've already got a good starting point - Marvin's, but other than that and on an old EM machine like this, just make sure all switches are cleaned (with a file, never spray anything into these machines) and adjusted properly (observe their action when pressing the fiberboard on the switch stack), ensure your jones' plugs are plugged in properly and all fuses are good and at the correct values. Score reels need to be taken apart entirely, cleaned, adjusted and put back together. NEVER use grease on coil plungers or nylon gears - EVER. You'll just gum up the action and make it that much more difficult for us to repair in the future.
Search the web and 'Google Groups' for a replacement motor. They're out there....
#4 MichaelJMcKernan OFFLINE
MichaelJMcKernan
    Moonsweeper
  • 440 posts
Posted Sun Dec 26, 2010 1:30 AM
Well, when plugging it the machine does...nothing at all.
What would be the next step?
#5 DanBoris OFFLINE
DanBoris
    Dragonstomper
  • 930 posts
Posted Sun Dec 26, 2010 7:40 AM
If it does nothing then start with the obvious, there is probably a fuse somewhere in the machine I would check that first.
Dan
#6 MichaelJMcKernan OFFLINE
MichaelJMcKernan
    Moonsweeper
  • 440 posts
Posted Sun Dec 26, 2010 8:07 AM
Okay, I will look at the fuses and report back. Thanks.
#7 BigO OFFLINE
BigO
  • 2,939 posts
Posted Sun Dec 26, 2010 8:28 AM
Dan
Does plugging in include turning on? Is there a power switch?
#8 MichaelJMcKernan OFFLINE
MichaelJMcKernan
    Moonsweeper
  • 440 posts
Posted Sun Dec 26, 2010 12:15 PM
Yes.
