0
Lotharek SDX board installation
18 replies to this topic
#1 erazmus OFFLINE
erazmus
    Star Raider
  • 72 posts
Posted Tue Nov 30, 2010 10:54 AM
Does anyone have the correct installation instructions for the Lotharek SDX board found here:
http://lotharek.pl/5/product/info/19
I just received one, but the documentation is very sparse. The docs talk about connecting wires to p7, p8, p12, etc on the SDX board, but the board I have has two connectors labelled J1 and J2. I've emailed Lotharek for more information, but thought I'd check here to see if anyone else has successfully installed one.
#2 flashjazzcat OFFLINE
flashjazzcat
  • 5,408 posts
  • Jumping through hOOPs...
Posted Tue Nov 30, 2010 11:04 AM
I've fitted several of these, but of the old design (it's changed). The docs he's hosting on his site refer to the old design. Without a schematic of the new board, I can't really advise. I suggest you lobby Lotharek to make some up-to-date documentation available for his products.
#3 erazmus OFFLINE
erazmus
    Star Raider
  • 72 posts
Posted Tue Nov 30, 2010 11:09 AM
Once I get a response from him, I'll post the details here (because this forum comes up in Google searches for all sorts of Atari stuff). I'll even write up some nice English installation instructions for him to post on his site. The product is wonderful, just lacking a bit on the documentation.
I have a question for you. The multi-OS-ROM option - are you using the ROM image that he provided? Wouldn't I have to replace the ROM (I assume his ROM image is PAL) with an NTSC version?
#4 flashjazzcat OFFLINE
flashjazzcat
  • 5,408 posts
Posted Tue Nov 30, 2010 12:29 PM
That would be really useful and appreciated by all I'm sure. Lotharek sells some great products (both my 1MB upgrades are his, plus the IntSDXs and a stereo board), but it sometimes takes him a while to put the documentation together. It once took me about a fortnight to fit a 1MB upgrade to my 800XL, drip-fed instructions (to supplement the half-finished docs) on the forum. :)
Quote
Well, I'm PAL anyway but surely the Atari OS is universal, i.e. it senses PAL/NTSC from the custom ICs on the machine.
#5 erazmus OFFLINE
erazmus
    Star Raider
  • 72 posts
Posted Sat Dec 4, 2010 3:26 AM
I heard back from Lotharek. Here's the pin-outs for the J1 and J2 connectors on the new SDX board.
The connections are listed from left to right as they appear on the board. The right-most pin is pin 1.
J1
8. H7
7. P7
6. H8
5. P8
4. H12
3. P12
2. H19
1. P19
J2
4. RW
3. 02
2. T3
1. CCTL (pin 10 of 74LS138)
With this wiring, I was able to install the SDX board. I'm very impressed. Works very well, and comes already flashed.
#6 Almost Rice OFFLINE
Almost Rice
  • 1,993 posts
  • Prius rocks
Posted Sat Dec 4, 2010 10:49 AM
How much was it shipped to you. I should have gotten this before the dollar became weak against the euro
#7 erazmus OFFLINE
erazmus
    Star Raider
  • 72 posts
Posted Sat Dec 4, 2010 12:34 PM
31 euro including shipping to Canada (didn't look at my Paypal account to see the exchange rate). Arrived in a week. No additional customs or duty.
#8 Louis OFFLINE
Louis
    Space Invader
  • 43 posts
Posted Tue May 17, 2011 12:44 PM
View Posterazmus, on Sat Dec 4, 2010 3:26 AM, said:
J2
4. RW
3. 02
2. T3
I already got this board from Lotharek, but I have no clue what a RW, O2, T3 is.
Although I have no problems finding the CCTL on pin 10 of 74LS138 :P
Can someone point me to the right direction?
Louis
#9 flashjazzcat OFFLINE
flashjazzcat
  • 5,408 posts
Posted Tue May 17, 2011 12:49 PM
Excerpts from the manual:
O2 – 39th pin of processor (6502, CO14806)
RW – 36th pin of processor (6502, CO14806)
10 – 10th pin of 74LS138 on ATARI mainboard
Find GTIA (U17 - CO14889). Desolder only leg 11 and bend it up slowly ! Connect with T3 on SDX board.
If you're looking in an XE, CO14806 is the 40 pin chip at the back-centre of the board. GTIA is the third and last 40 pin IC from the back of the machine in the same column of chips.
If you need any more help, let me know, since I've installed three of these in various machines.
Edited by flashjazzcat, Tue May 17, 2011 12:50 PM.
#10 Louis OFFLINE
Louis
    Space Invader
  • 43 posts
Posted Tue May 17, 2011 12:55 PM
great (and fast) help! thanks!
#11 Louis OFFLINE
Louis
    Space Invader
  • 43 posts
Posted Tue May 17, 2011 1:20 PM
ok, maybe too soon :P
I managed to do all the above.
I ran the SDX flash utility (SDX443_intsdx128flash.atr).
I'm getting: SDX is off, and Warning: Flash not found.
I used different OS jumper settings...
Any ideas?
#12 flashjazzcat OFFLINE
flashjazzcat
  • 5,408 posts
Posted Tue May 17, 2011 1:26 PM
Hmmm... that's one thing I don't do: I program the EEPROMs using a programmer. I often experienced trouble with the flash utilities before that. Does it work with the pre-installed SDX?
IIRC, I used to do a "COLD /N" with the flasher in the drive, then push the jumper on the "Flash" pins while the computer was rebooting. Something like that...
#13 Louis OFFLINE
Louis
    Space Invader
  • 43 posts
Posted Tue May 17, 2011 1:48 PM
It doesn't do anything special.
I mean... It doesn't boot to SDX.
That's why I thought it was not programmed at all.
When should it boot to SDX?
#14 flashjazzcat OFFLINE
flashjazzcat
  • 5,408 posts
Posted Tue May 17, 2011 1:56 PM
It should boot to SDX when the "Off" and "Flash" pins aren't jumpered. Sounds like something's not right here.
#15 Louis OFFLINE
Louis
    Space Invader
  • 43 posts
Posted Tue May 17, 2011 2:10 PM
J1
8. H7
7. P7
6. H8
5. P8
4. H12
3. P12
2. H19
1. P19
I should probably wire these too right?
I was under the impression that this was only necessary with the memory upgrade...
Were can I find the these pinouts?
[edit]
Connect with thin wires:
p7 on SDX PCB → bended up MMU pin7
p8 on SDX PCB → bended up MMU pin8
p12 on SDX PCB → bended up MMU pin12
p19 on SDX PCB → bended up MMU pin19
h7 on SDX PCB → hole in mainboard after MMU pin 7
h8 on SDX PCB → hole in mainboard after MMU pin 8
h12 on SDX PCB → hole in mainboard after MMU pin 12
h19 on SDX PCB → hole in mainboard after MMU pin 19
[/edit]
Edited by Louis, Tue May 17, 2011 2:13 PM.
#16 flashjazzcat OFFLINE
flashjazzcat
  • 5,408 posts
Posted Tue May 17, 2011 2:16 PM
Heh... no wonder it doesn't work. But the manual leaves a lot to be desired, so I can't blame you for being confused.
The numbers refer to holes and pins of the MMU, (U3 - CO61618), which on the XE is situated immediately to the left of where you've fitted the IntSDX board. "H" refers to the holes left in the PCB after you've lifted the relevant pins, and "P" refers to the lifted pin itself. You need to carefully desolder pins 7, 8, 12, and 19, and gently prise them out of the holes, bending them up so that you can make the "P" connections to the raised pins, and the "H" connections to the vacated holes. I can heartily recommend socketing the MMU (or getting someone to socket it for you). My personal preference is to socket the chip, and then run the "H" wires along the underside of the board. At the very least I would advise desoldering and removing the whole chip before bending up the pins, since it's all too easy to snap a leg off the chip if you don't make a good job of it.
Edited by flashjazzcat, Tue May 17, 2011 2:17 PM.
#17 Louis OFFLINE
Louis
    Space Invader
  • 43 posts
Posted Tue May 17, 2011 3:09 PM
Still no luck.
I'm trying this on a 800XL Freddy PCB.
I had some trouble in the past with this board, so almost all the IC's are socketed.
I'm using old UTP-wiring which can be bend and pushed into the 'H'oles.
Maybe I shouldn't be using this kind of wire, since in the manual is stated "connect with thin wires".
I'm not exactly sure what "thin" is :P
Well, tomorrow is another day.
#18 w1k OFFLINE
w1k
    Dragonstomper
  • 744 posts
Posted Sun Feb 5, 2012 3:37 AM
well, what is a end of your installation?
#19 Rybags ONLINE
Rybags
  • 10,313 posts
Posted Sun Feb 5, 2012 4:21 AM
UTP wiring should be fine for signalling. Just test the connection with a multimeter once installed.
