Xybots Joystick
10 replies to this topic
#1 Zoyx OFFLINE
Zoyx
  • 1,095 posts
Posted Sun Dec 5, 2010 11:40 AM
What is a good replacement for a xybots joystick in a mame setup?
Edited by Zoyx, Sun Dec 5, 2010 11:40 AM.
#2 Cebus Capucinis ONLINE
Cebus Capucinis
    Unpaid Janitor
  • 6,519 posts
  • AtatiAge "New Life" Counselor
Posted Sun Dec 5, 2010 12:06 PM
AFAIK there is none, unless you have a joysick that also serves a rotary function.
I guess you could always map 'rotate left' and 'rotate right' to a couple buttons if you have more than 4 buttons on your setup. That might work.
#3 keilbaca OFFLINE
keilbaca
    Salame!
  • 7,185 posts
  • Code Monkey like Tab and Mt. Dew
Posted Mon Dec 6, 2010 4:07 PM
The original joystick is spring loaded, and when you twisted it left or right, it hit a leaf switch to target it.
You might not be able to do the spring portion, but it should be pretty easy if the joystick hangs down a bit to come up with something that attaches to the bottom.
I wish I still had my Xybots, or else I'd take a pic of the joystick for you.
#4 Zoyx OFFLINE
Zoyx
  • 1,095 posts
Posted Mon Dec 6, 2010 4:11 PM
I used to own a Xybots, but gave it to a friend.
I am making progress. I have a couple of PC joysticks that twist, but are too sensitive. I need to increase the deadzone. Once I figure that out, I should have a winner.
#5 BigO OFFLINE
BigO
  • 2,939 posts
Posted Mon Dec 6, 2010 4:31 PM
There's that Ms. Pac-man Plug-n-play with Pole Position. It has a rotary action in the joystick for steering. If you happen to be building a teensy, easily breakable MAME machine, you're all set..
#6 jhd OFFLINE
jhd
    Moonsweeper
  • 450 posts
Posted Mon Dec 6, 2010 6:13 PM
This is how it is handled in the Midway Arcade Treasures collection (Volume 2) on the PS 2, at least -- the shoulder buttons are used to rotate. It makes the game nearly unplayable.
#7 Zoyx OFFLINE
Zoyx
  • 1,095 posts
Posted Mon Dec 6, 2010 6:17 PM
I tried this with a couple spare buttons on my mame setup, and had some success. Not as instinctual as the twist, however.
#8 patbb OFFLINE
patbb
    Dragonstomper
  • 927 posts
Posted Tue Dec 7, 2010 12:13 PM
I did not know that, thanks for the info.
#9 Crazy Climber OFFLINE
Crazy Climber
    Crazy Climberer
  • 9,900 posts
  • Star Odysseyer
Posted Wed Dec 8, 2010 8:31 PM
Those things are pretty cheap though, I doubt they would work very well.
#10 RJ ONLINE
RJ
  • 2,281 posts
Posted Fri Dec 17, 2010 11:22 AM
Quote
...the shoulder buttons are used to rotate. It makes the game nearly unplayable.
Umm, I beg to differ- maybe it's just me but I can whip around left & right rather well in that version. Works pretty good IMO.
#11 patbb OFFLINE
patbb
    Dragonstomper
  • 927 posts
Posted Mon Dec 20, 2010 1:00 PM
Found this on Flickr.com
It showing the joystick for inside.
The Right/Left portion looks like a simple thing to do but like Keibaca was saying the spring action might be difficult.
more here
