0
S-video panel/chassis mount jack
18 replies to this topic
#1 horseboy OFFLINE
horseboy
  • 1,226 posts
Posted Fri Dec 10, 2010 3:22 PM
Does anyone know where to get the gold plated S-Video panel/chassis mount jacks that Longhorn uses on his Deluxe mods? I can't find them anywhere. I am sure I am just using the wrong search terms or something. I can only find the ones that need screws for mounting and I hate that. I can find panel/chassis mount screwless jacks that have a female connector on both ends, but I would really like for it to be a solder connection on one side. Here is a pic from Longhorn's page....
Posted Image
#2 frank_c OFFLINE
frank_c
    Chopper Commander
  • 216 posts
Posted Fri Dec 10, 2010 4:46 PM
S-video bulkhead connector?
http://www.svideo.com/35498ks.html
#3 horseboy OFFLINE
horseboy
  • 1,226 posts
Posted Fri Dec 10, 2010 8:07 PM
Nope. There are some items on there that are better than the kind with screws showing, but not the same thing as longhorn's. This guy used the same jack...
Edited by horseboy, Fri Dec 10, 2010 8:10 PM.
#4 jamesk OFFLINE
jamesk
    Moonsweeper
  • 252 posts
Posted Fri Dec 10, 2010 11:31 PM
Did you try a search for 4 pin mini DIN. I would check Mouser. E-mail them with a picture and description of the item.
#5 horseboy OFFLINE
horseboy
  • 1,226 posts
Posted Sat Dec 11, 2010 2:10 PM
Yeah, I searched 4 pin mini DIN. I checked out mouser pretty heavily too. I guess an email to them might be the best thing at this stage. That is unless Longhorn logs on and lets me know.
#6 Foster OFFLINE
Foster
    Chopper Commander
  • 101 posts
Posted Sun Dec 12, 2010 10:32 PM
This looks like the one. http://www.parts-exp...umber=091-1212.
... Foster
#7 Foster OFFLINE
Foster
    Chopper Commander
  • 101 posts
Posted Sun Dec 12, 2010 10:39 PM
Err. scratch that. I just noticed that it has female s-video connectors on both sides. www.parts-express.com. SKU 091-1212.
#8 Murph74 OFFLINE
Murph74
  • 1,104 posts
  • Gotta get home to my ColecoVision!
Posted Sun Jan 9, 2011 1:28 PM
Like this?
http://www.comprehen...-connector.html
If so, it appears to be on sale here:
http://www.ccisoluti...Origin=Category
Although, this looks more like it in gold but appears to be the pass-thru barrel type:
http://www.kvconnect.../t-sv4-blcm.htm
#9 FABombjoy OFFLINE
FABombjoy
    Moonsweeper
  • 404 posts
Posted Mon Jan 10, 2011 12:14 PM
I remember that in the Neo Geo world, this particular style of S-video jack was quite popular. The typical procedure was to buy the one you've seen with female connectors on both sides and cut it open, connecting your circuit directly to the wires that join the 2 connectors together.
I bought one of those once to see if it was worth the effort. It was easy to open with a pipe cutter, but the wires inside were so thin and fragile that I never considered using them full time. Unless you've gotta have the appearance of gold, there are panel jacks that are much easier to use and higher quality.
Edited by FABombjoy, Mon Jan 10, 2011 12:15 PM.
#10 horseboy OFFLINE
horseboy
  • 1,226 posts
Posted Mon Jan 10, 2011 2:51 PM
Lay them on me. I am open to anything. Quality is the most important thing.
#11 doyman OFFLINE
doyman
    Chopper Commander
  • 146 posts
Posted Mon Jan 10, 2011 3:34 PM
I asked Parker about these and here is his reply:
I order them from PartsExpress.
http://www.parts-exp...number=091-1203
http://www.parts-exp...number=091-1204
http://www.parts-exp...number=091-1212
S-video connector needs to be cut in half to be used.
Parker
#12 FABombjoy OFFLINE
FABombjoy
    Moonsweeper
  • 404 posts
Posted Mon Jan 10, 2011 5:56 PM
091-1212 is the part I've used too. Easiest way to open it up is with a pipe cutter.
This style is probably my favorite, although I'm not sure if Mouser has the best price for them (plus they're currently OOS).
Edited by FABombjoy, Mon Jan 10, 2011 5:59 PM.
#13 Murph74 OFFLINE
Murph74
  • 1,104 posts
Posted Mon Jan 10, 2011 6:19 PM
Parker
Bad links, my friend.
Fixed! :)
#14 doyman OFFLINE
doyman
    Chopper Commander
  • 146 posts
Posted Mon Jan 10, 2011 7:55 PM
Sorry 'bout that. :ponder:
#15 BillC OFFLINE
BillC
    Moonsweeper
  • 495 posts
Posted Sat Jan 29, 2011 5:13 AM
Posted Image
This is an panel/bulkhead mount s-video jack to solder terminal in a keystone jack.
http://www.showmecab...?idProduct=2567
Posted Image
This is the similar to the one above, without the gold plating, for a lower price.
http://www.pimfg.com...tail/SPM-DNG-WH
Posted Image
#16 A.J. Franzman OFFLINE
A.J. Franzman
  • 4,326 posts
  • Syzygyst
Posted Sat Jan 29, 2011 5:59 PM
That's the ticket! The second one has the wrong image (female DIN jack to female DIN jack), but the description and technical drawing (on the "Data Sheet" tab) at the site show it is jack to solder.
Edited by A.J. Franzman, Sat Jan 29, 2011 6:02 PM.
#17 BillC OFFLINE
BillC
    Moonsweeper
  • 495 posts
Posted Wed Mar 30, 2011 10:09 PM
Just an update for those looking a deal on solder type s-video jack, the price of these has dropped to $0.40 in beige, $0.50 in white. Just remove from the keystone adapter and it is chassis mount.
The wrong image (female DIN jack to female DIN jack) is given, but the description and technical drawing (on the "Data Sheet" tab) at the site show it is jack to solder.
Posted Image
#18 mamejay OFFLINE
mamejay
    Chopper Commander
  • 102 posts
Posted Tue Apr 19, 2011 7:39 PM
I use these for all my console mods.
eBay Auction -- Item Number: 260599682588
Super cheap and if you drill the hole right they look factory installed.
Just hit them with a hot glue gun from the inside so they don't move.
Not as fancy as the steel connectors but at least there are no screw holes to drill.
#19 horseboy OFFLINE
horseboy
  • 1,226 posts
Posted Fri May 27, 2011 8:31 AM
UPDATE
Forget showmecables. The PI product and Showmecables product are the exact same. PI has the wrong picture. They are both the same as pictured at showmecables. Both have the gold plating. Exact same product. Buy them at PI save a bunch of money.
Posted Image
Posted Image
Posted Image
Edited by horseboy, Fri May 27, 2011 8:32 AM.
