simbo, on Fri Jan 14, 2011 5:18 PM, said:
remove the 3.579575 mhz crystal and turn it round solder in
change the 4.7uf and 2200uf electrolytics near to the regulator ic
infact all the can electrolytics ...!
watch for and replace the 2n3906 transistor associated with the crystal
i would use a bc547C type and watch the pinout it right
it has a higher gain
i think you should look for and replace the crystal
it controls everything colour etc
turning it around is enough
same goes for carts and there resonators.. and crystals
Man, what have you been smoking? Nothing of what you wrote, that I've quoted above, could possibly have anything to do with his unit's symptoms. If the crystal or any of its associated components are bad, the console WILL NOT WORK AT ALL, because the output from the crystal oscillator is the master clock for all of the main ICs. If a crystal is borderline in some way that causes it to have polarity, such that turning it around makes the circuit work, take that crystal back out and throw it away! Like science and belief in the supernatural, electronics and "New Age" superstitions about supposed powers of crystals do not mix. No VCS unit that I'm aware of contains a resonator (which is a module sometimes found in even older electronics, that performs the same function as a crystal).
Also, you seem to be advocating what we technicians call a "shotgun" approach. Reversing one component and replacing a bunch of others in the hope that one of them might be the bad part, is hardly the right way to go about a repair job. The first steps should be diagnosis -- testing various voltages and signals on the board to narrow down exactly where the problem lies. Only after having a reasonably sound diagnosis, should one begin the treatment phase. Sometimes the diagnostic process itself might involve replacing a component or two (especially when attempting to help an electronics novice by long-distance communication), and occasionally that replacement may in fact fix the unit. But the shotgun approach is generally far less than the optimal solution, especially considering that a novice making a bunch of component replacements could end up doing more harm than good.
sometimes the associated zener diode or other diodes and caps goes leaky{rare} to the colour control pot
its unlikely the regulator is damaged as it would not work
bad solders maybe
beware for a faulty colour delay pot...!
These are the only sensible ideas from your post, except that there's no zener diode in the color circuit (nor the crystal oscillator circuit either).
Edited by A.J. Franzman, Sat Jan 15, 2011 11:42 PM.
