Trouble with Visualbb
18 replies to this topic
#1 orionpax55 OFFLINE
orionpax55
    Space Invader
  • 27 posts
Posted Sun Feb 6, 2011 6:02 PM
When I open Visual Batari Basic the only things that work are file, edit, view, and build.
#2 jwierer OFFLINE
jwierer
    Dragonstomper
  • 746 posts
Posted Sun Feb 6, 2011 10:56 PM
Sounds about right. The next step is to create something ;) I recommend RT's vbB to help get you started.
-Jeff
#3 orionpax55 OFFLINE
orionpax55
    Space Invader
  • 27 posts
Posted Mon Feb 7, 2011 5:33 PM
-Jeff
My apologies, allow me to be more specific. I've created (and loaded) a project, afterwards things like double-clicking default.bas or creating playfeilds and sprites don't work.
Edited by orionpax55, Mon Feb 7, 2011 5:34 PM.
#4 jwierer OFFLINE
jwierer
    Dragonstomper
  • 746 posts
Posted Mon Feb 7, 2011 6:58 PM
Sounds about right. The next step is to create something Posted Image I recommend RT's vbB to help get you started.
-Jeff
This is actually covered in Post #1
  • If you're having trouble using the sprite/playfield editor go here for a registry fix.
#5 orionpax55 OFFLINE
orionpax55
    Space Invader
  • 27 posts
Posted Mon Feb 7, 2011 8:27 PM
-Jeff
I followed the instructions and it didn't work, so then it said to "open regedit", and I don't know what that is.
#6 jwierer OFFLINE
jwierer
    Dragonstomper
  • 746 posts
Posted Mon Feb 7, 2011 11:49 PM
Close Visual bB. Double Click the .reg file. If it asks if you want to do this, click yes. Make sure you don't an A/V program blocking registry changes. Reopen Visual bB. If it doesn't work, you're running something that blocks editing the registry and/or you aren't a local administrator.
-Jeff
#7 orionpax55 OFFLINE
orionpax55
    Space Invader
  • 27 posts
Posted Tue Feb 8, 2011 12:28 AM
-Jeff
I'm still having some trouble, but the I appreciate the help.
#8 jwierer OFFLINE
jwierer
    Dragonstomper
  • 746 posts
Posted Tue Feb 8, 2011 5:00 AM
-Jeff
1. Open up the .reg file with a text editor.
2. Go from Start->Run and then type regedit
3. Using the Regisry Editor browse to the hive and make sure the settings in the registry match the .reg file, if not manually make the changes
Try vbB again.
-Jeff
#9 orionpax55 OFFLINE
orionpax55
    Space Invader
  • 27 posts
Posted Tue Feb 8, 2011 8:41 PM
-Jeff
Try vbB again.
-Jeff
Okay, unless those quotation marks matter, the settings match, and now Vbb works for a little bit, maybe, a minute, and then freezes up.Also, and I just noticed this, (Default) says (value not set), is that a problem?
Edited by orionpax55, Tue Feb 8, 2011 8:45 PM.
#10 jwierer OFFLINE
jwierer
    Dragonstomper
  • 746 posts
Posted Tue Feb 8, 2011 9:38 PM
Please describe freezing up. Are you in the middle of some action when it happens. If you post a screen shot perhaps we all get a better idea of the problem you're having.
-Jeff
#11 orionpax55 OFFLINE
orionpax55
    Space Invader
  • 27 posts
Posted Tue Feb 8, 2011 10:49 PM
-Jeff
Here you go. The things I clicked on did open this time, but it was really delayed, not that you can't see. As far as I know, there isn't any specific action that triggers it, and as I mentioned in the first post, the things at the very top work just fine.
#12 jwierer OFFLINE
jwierer
    Dragonstomper
  • 746 posts
Posted Tue Feb 8, 2011 11:00 PM
Everything looks correct. Load times will depend on the speed of your computer. Slower models are simply going to take longer. I have a dual core 32-bit laptop and most items, with the exception of long pieces of code, load in less than a second. If you disable color coding in your settings tab, code should open instantly. If you get an error message be sure to post it, otherwise I'd say it's functioning as expected.
-Jeff
#13 orionpax55 OFFLINE
orionpax55
    Space Invader
  • 27 posts
Posted Wed Feb 9, 2011 4:45 PM
-Jeff
I have yet to get any error messages, but disabling color coding didn't seem to do anything, do you know any other ways to speed Vbb up?
#14 jwierer OFFLINE
jwierer
    Dragonstomper
  • 746 posts
Posted Wed Feb 9, 2011 7:18 PM
Are you running this on a netbook or something really old?
#15 orionpax55 OFFLINE
orionpax55
    Space Invader
  • 27 posts
Posted Wed Feb 9, 2011 8:15 PM
a netbook, an Acer Aspire One, to be more specific.
#16 Random Terrain ONLINE
Random Terrain
    Visual batari Basic User
  • 20,918 posts
  • Controlled Randomness
    Replay Value
    Nonlinear
Posted Wed Feb 9, 2011 9:14 PM
If your computer is slow, do you also have Enable Syntax Checking turned off? If you have that and color coding turned off, it should speed things up.
#17 orionpax55 OFFLINE
orionpax55
    Space Invader
  • 27 posts
Posted Wed Feb 9, 2011 9:45 PM
It's been turned off, and it's still incredibly slow.
#18 jwierer OFFLINE
jwierer
    Dragonstomper
  • 746 posts
Posted Wed Feb 9, 2011 11:05 PM
That is your problem. A single core Intel Atom processor was not meant for software development. I also have one of those and if I'm doing anything other than browsing the web it's damn slow. Sorry you'll need a real laptop to get any performance. You're probably out of memory by the time vbB loads.
-Jeff
#19 orionpax55 OFFLINE
orionpax55
    Space Invader
  • 27 posts
Posted Wed Feb 9, 2011 11:44 PM
-Jeff
Well darn, I guess I'll just have type everything out manually, and then assemble it in dasm, huh? Anyways, I appreciate the help, be seeing you around the forums.
