walter_J64bit Posted February 13, 2011 Share Posted February 13, 2011 Is the 3.5 mod for the XF551 even worth the time and who can do this mod? What DOSes work with mod? Quote Link to comment Share on other sites More sharing options...
+bf2k+ Posted February 14, 2011 Share Posted February 14, 2011 Is the 3.5 mod for the XF551 even worth the time and who can do this mod? What DOSes work with mod? Change the drive and plug in an EPROM? I think that's all there is to it. I use mine with SpartaDOS 3 & X. Quote Link to comment Share on other sites More sharing options...
+bob1200xl Posted February 14, 2011 Share Posted February 14, 2011 All the DOS variants work with it, but that doesn't mean that DOS 2.5 will format out to 720K, any more than it would format out to 360K before the mod. Bob Is the 3.5 mod for the XF551 even worth the time and who can do this mod? What DOSes work with mod? Quote Link to comment Share on other sites More sharing options...
walter_J64bit Posted February 15, 2011 Author Share Posted February 15, 2011 All the DOS variants work with it, but that doesn't mean that DOS 2.5 will format out to 720K, any more than it would format out to 360K before the mod. Bob Is the 3.5 mod for the XF551 even worth the time and who can do this mod? What DOSes work with mod? Oh, I didn't know that you can use any DOS. I take it with that mod, you can setup the drive with partitions to work like multiple disk drives in one drive. (like HyperXF with two partitions on a 5.25 drive) Quote Link to comment Share on other sites More sharing options...
walter_J64bit Posted February 15, 2011 Author Share Posted February 15, 2011 (edited) Is the 3.5 mod for the XF551 even worth the time and who can do this mod? What DOSes work with mod? Change the drive and plug in an EPROM? I think that's all there is to it. I use mine with SpartaDOS 3 & X. Who moded your drive, is possible I can get him to mod my XF551? Edited February 15, 2011 by walter_J64bit Quote Link to comment Share on other sites More sharing options...
+bf2k+ Posted February 15, 2011 Share Posted February 15, 2011 Is the 3.5 mod for the XF551 even worth the time and who can do this mod? What DOSes work with mod? Change the drive and plug in an EPROM? I think that's all there is to it. I use mine with SpartaDOS 3 & X. Who moded your drive, is possible I can get him to mod my XF551? I got it off of ebay more than 10 years ago - don't know who did the mod. It looks very easy to do providing you can get the EEPROM burnt. Quote Link to comment Share on other sites More sharing options...
MEtalGuy66 Posted February 15, 2011 Share Posted February 15, 2011 This has been discussed in here like 10 times.. Use the advanced search feature to search for threads that have "XF551" in the title. All you need is a 720k drive mech, a 5.25" to 3.5" floppy connector adptor, and a 5.25" to 3.5" footprint drivebay adaptor with faceplate. You also have to jumper the 3.5" drivemech as DS0 instead of DS1.. And replace the ROM in the XF551. Quote Link to comment Share on other sites More sharing options...
Marius Posted February 15, 2011 Share Posted February 15, 2011 This has been discussed in here like 10 times.. Use the advanced search feature to search for threads that have "XF551" in the title. All you need is a 720k drive mech, a 5.25" to 3.5" floppy connector adptor, and a 5.25" to 3.5" footprint drivebay adaptor with faceplate. You also have to jumper the 3.5" drivemech as DS0 instead of DS1.. And replace the ROM in the XF551. Is it (by the way) possible to use High density disks? I've heard in the past that the Atari ST diskdrives would not be very pleased with them, because of a different BIAS of the magnetic film. Is this an issue? HD diskettes are rather easy to get (new) Quote Link to comment Share on other sites More sharing options...
walter_J64bit Posted February 15, 2011 Author Share Posted February 15, 2011 This has been discussed in here like 10 times.. Use the advanced search feature to search for threads that have "XF551" in the title. All you need is a 720k drive mech, a 5.25" to 3.5" floppy connector adptor, and a 5.25" to 3.5" footprint drivebay adaptor with faceplate. You also have to jumper the 3.5" drivemech as DS0 instead of DS1.. And replace the ROM in the XF551. That sound easy to do. I might look into that, I'm not getting anywhere with try to find a 5.25" 360kb drive mech. Quote Link to comment Share on other sites More sharing options...
puppetmark Posted February 15, 2011 Share Posted February 15, 2011 That sound easy to do. I might look into that, I'm not getting anywhere with try to find a 5.25" 360kb drive mech. Many 1.4mb drives can run as a 720K drive. Although, sometimes they need a jumper soldered. I can burn you an EPROM if you need one. Quote Link to comment Share on other sites More sharing options...
walter_J64bit Posted February 16, 2011 Author Share Posted February 16, 2011 Do you all think this can work on the XF551, that's been moded to run a 3.5" drive. Disk drive EMULATOR" eBay Auction -- Item Number: 110648496807 Quote Link to comment Share on other sites More sharing options...
BillC Posted February 17, 2011 Share Posted February 17, 2011 Do you all think this can work on the XF551, that's been moded to run a 3.5" drive. Disk drive EMULATOR" eBay Auction -- Item Number: 110648496807 That is a drive emulator for an Amiga or an Atari ST computer, not a disk drive upgrade. Drive images are stored on a SD card, and the computer sees the images as if they are actual disks/drives. The SIO2SD and SDrive are similar devices for the Atari 8-bit computers. Quote Link to comment Share on other sites More sharing options...
Rybags Posted February 17, 2011 Share Posted February 17, 2011 (edited) That actually works somewhat differently to one of our SIO2* devices. It's a whole "lower level" of emulation in that it actually intercepts and interprets data and track movement commands that the controller sends to the actual drive mechanism. I'd say it's entirely plausible that it might work with an XF551 drive in place of a 3.5" drive, just that nobody's tried yet. Although it's a somewhat pricey purchase (won't surprise me if that ends over $100). You'd have no trouble moving it on if it didn't work on an XF drive. All that aside though, it'd be an arse-about way to achieve the exact same thing that SIO2SD and SDrive do anyhow, plus it'd likely be a lot less flexible insofar as stuff like variable SIO speeds, and host-sent commands to do stuff like mount images. Edited February 17, 2011 by Rybags Quote Link to comment Share on other sites More sharing options...
MEtalGuy66 Posted February 17, 2011 Share Posted February 17, 2011 (edited) Dont buy that pile of crap.. DO not deface an XF551 with YET ANOTHER stupid flash device.. If what you want is a flash based disk emulator for the ATARI, theres plenty of them available.. Fix the drive RIGHT.. Dont be so impatient. Send me the drive and I'll fix for you for FREE.. You just pay shipping and parts. Or sell it to someone who will fix it. There are MANY people on here that would jump at the chance to buy a non-functional XF551.. And do what I already said.. READ ALL THE EXISTING XF551 THREADS.. Don't just start a completely redundant thread any time you have a question.. Use the SEARCH FEATURE first.. Edited February 17, 2011 by MEtalGuy66 Quote Link to comment Share on other sites More sharing options...
walter_J64bit Posted February 19, 2011 Author Share Posted February 19, 2011 Dont buy that pile of crap.. DO not deface an XF551 with YET ANOTHER stupid flash device.. If what you want is a flash based disk emulator for the ATARI, theres plenty of them available.. Fix the drive RIGHT.. Dont be so impatient. Send me the drive and I'll fix for you for FREE.. You just pay shipping and parts. Or sell it to someone who will fix it. There are MANY people on here that would jump at the chance to buy a non-functional XF551.. And do what I already said.. READ ALL THE EXISTING XF551 THREADS.. Don't just start a completely redundant thread any time you have a question.. Use the SEARCH FEATURE first.. Sweet! I'll MP here you soon, I'm going to be looking for something to ship the drive off in. Quote Link to comment Share on other sites More sharing options...
