0
Analogue Joysticks?
16 replies to this topic
#1 Atari_Owl OFFLINE
Atari_Owl
    Dragonstomper
  • 954 posts
Posted Sun Dec 15, 2002 11:05 AM
Is anybody aware of any Analogue joysticks for the Jaguar?
I'm aware they stopped including the ADCs in the Jag, but were there every any Analogue sticks tha worked with it?
Cheers guys
#2 Guyôme OFFLINE
Guyôme
    Space Invader
  • 13 posts
Posted Sun Dec 15, 2002 5:15 PM
I've heard once that best electronics has converted the blackhawk joystick.
But I've seen it on the website.
#3 Thunderbird OFFLINE
Thunderbird
  • 2,501 posts
Posted Sun Dec 15, 2002 6:45 PM
Cheers guys
If you have a K-series Jaguar you can convert just about any PC analog joystick to work with BattleSphere and/or BattleSphere Gold™, in true Analog mode. It's one of the codes in the game. It works too!
#4 JagMod OFFLINE
JagMod
    Chopper Commander
  • 200 posts
Posted Sun Dec 15, 2002 7:13 PM
What's the difference between the K series and M series jags when it comes to analog joysticks?
JagMod
#5 Thunderbird OFFLINE
Thunderbird
  • 2,501 posts
Posted Sun Dec 15, 2002 7:23 PM
JagMod
M series are the el-cheapo Motorola cost-reduced versions without the analog circuits for the Joypads.
#6 JagMod OFFLINE
JagMod
    Chopper Commander
  • 200 posts
Posted Sun Dec 15, 2002 7:26 PM
Can you elaberate on this a little?
I wasn't aware that the later jags were inferior to the K series.
Are you saying that they eliminated hardware in the M series jags?
JagMod
#7 Thunderbird OFFLINE
Thunderbird
  • 2,501 posts
Posted Sun Dec 15, 2002 7:31 PM
JagMod
You have the Jaguars.
Open them up and see.
Sorry to be the bearer of bad news.
#8 Atari_Owl OFFLINE
Atari_Owl
    Dragonstomper
  • 954 posts
Posted Mon Dec 16, 2002 5:17 AM
Quote
I have 2 K series and an M.
The main difference i see is that my copy of Rayman plays on the M series but not on either of the K series.
Is that weird to my machines or has anybody else seen this?
#9 Guyôme OFFLINE
Guyôme
    Space Invader
  • 13 posts
Posted Mon Dec 16, 2002 5:34 AM
few I have a K version, but Rayman works on mine :?
I've heard that ATARI, for the last modelle Of jaguar has reduced the RAM
from 4MB to 2 MB, because no game where use the full ram iof the jaguar, ... they tried desperatall to save as much money as they can. THat's sad isn't ?
#10 Atari_Owl OFFLINE
Atari_Owl
    Dragonstomper
  • 954 posts
Posted Mon Dec 16, 2002 5:41 AM
Quote
Not sure what you mean there.
I'm pretty sure they all had 2MB ram.
Maybe i am misunderstanding what you mean?
#11 Guyôme OFFLINE
Guyôme
    Space Invader
  • 13 posts
Posted Mon Dec 16, 2002 5:43 AM
no it's me because in France we don't say MBits but MOctets, and I'm a newvie, so I don't how we that that, or this, so it's my mistake.
But I'm sure I've heard this story some where, or something like that.
#12 Thunderbird OFFLINE
Thunderbird
  • 2,501 posts
They ALL had 2MB of RAM. Believe me, if any of them had 4MB then you would have seen some really cool stuff in BattleSphere™.
Atari DID at one point before the Jag came out try and reduce it from 2MB to 1MB, but all the developers said this would never be good enough so they left it at 2MB.
#13 Guyôme OFFLINE
Guyôme
    Space Invader
  • 13 posts
Posted Mon Dec 16, 2002 5:45 AM
Ah ok, thanks now I understand.
thanks
#14 Paolo OFFLINE
Paolo
    Dragonstomper
  • 895 posts
Posted Wed Dec 18, 2002 10:12 AM
Hey, T'bird.
I remember I read a lot of threads about the analogue affair, and I am sure I never heard about the PCjoystick conversion (obviously I may be wrong).
So, pleaspleaseplease tell me how to convert this PC joystick, and why nobody is selling adapted joysticks, since there are a few guys that know well how to hack hardware.
Bye
Paolo
#15 Thunderbird OFFLINE
Thunderbird
  • 2,501 posts
Posted Wed Dec 18, 2002 5:19 PM
Paolo said:
Hey, T'bird.
Bye
Paolo
I have told several people how to modify joysticks. One fellow said he was going to sell them so I deferred from making my own or publishing plans because I wanted to help him out. This was about 6 weeks ago, but I have not heard anythnig since.
Basically, the PC joystick uses a potentiometer where only 2 pins are used: one side and the center wiper. To work on the Jag, the sides of the pot have to be hooked to +5 and GND and the center goes to the analog pin of the joystick port on the Jag.
+5---////---GND
Input------|
(That will probably get messed up in HTML but you get the idea)
I don't know the exact pins to hook up right off my head, so someone will have to look it up. There's only 2 input pins on the port, UP/DOWN and LEFT/RIGHT. Hook up each pot and you'll be running. You'll have to use trial and error to figue out which end of each pot is +5 and which is GND because different pots wire them differently and if you get it wrong the only thing which will happen is your directions will be reversed when you play. Just reverse the connections to fix it.
#16 Paolo OFFLINE
Paolo
    Dragonstomper
  • 895 posts
Posted Thu Dec 19, 2002 4:01 PM
Well, having these infos near Christmas vacations, it looks like something more is adding at the "to do" list :D
Thanks!
#17 LinkoVitch OFFLINE
LinkoVitch
  • 1,955 posts
Posted Thu Dec 19, 2002 4:07 PM
an Octect is essentially a Byte. (8=oct so 8 bits is an octet). it's just a more clean accurate way of saying Byte.
to get the value in Mb (Megabits) just multiply by 8. so 2 MO= 16 Mb
2MO = 2 MB
