Any way to convert MIDI to Atari?
11 replies to this topic
#1 Pong OFFLINE
Pong
    Chopper Commander
  • 172 posts
Posted Mon Mar 7, 2011 10:19 AM
Most of my loops are, in fact, very short. Now is there some way to convert a MIDI to a format which can be used with the Atari 2600 or do I have to do it by hand?
#2 theloon OFFLINE
theloon
  • 1,015 posts
Posted Mon Mar 7, 2011 2:21 PM
I once thought of using MIDI to text converters and then matching the frequencies with those used in VisualbB. If you find a public domain MIDI conversion tool maybe the developer of VisualbB could make a "import" function for MIDI :)
#3 diogoandrei OFFLINE
diogoandrei
    Chopper Commander
  • 210 posts
Posted Mon Mar 7, 2011 3:46 PM
I think it might be possible (I am not a fully capable programmer), but I do believe itīs always the same issue: the TIA frequencies. So the converter will have to make decisions on how to approach the not-available/not-close enough frequencies. Also thereīs the timber question. If your loops are, letīsay, percussive ones, you will have to program the sounds using different distortions sometimes. For example, a good sounding snare might be achived using two different TIA distortions: one for the snapping sound and the other for the body sound of the snare.
I am not saying itīs impossible (please, donīt get me wrong - I would love to have a MIDI2TIA converter), but in a a first moment it looks like a pretty challenging quest. Nevertheless, it would be a really good feature for Visual bB! =)
#4 batari OFFLINE
batari
    )66]U('=I;B$*
  • 6,236 posts
  • begin 644 contest
Posted Mon Mar 7, 2011 5:11 PM
A member here wrote one, and although he didn't publish it, he sent it to me. It didn't work very well with the MIDI files I tried. It would only decode one channel, and MIDIs can have 16. This would be fine but it seems that even with simple songs, they use several channels even for what sounds like a single voice, so you get fragments of the tune, and need to run the program several times and manually reassemble the fragments into a single voice.
The MIDI-to-text converters look promising, though, and could be the basis for a converter.
There is also SID2TIA, which can convert a SID tune. With tweaking, and with the right SIDs (i.e. not the blippy ones that try to do two voices in a single channel) you can get decent results.
#5 RevEng OFFLINE
RevEng
  • 2,010 posts
  • bit shoveler
Posted Mon Mar 7, 2011 6:10 PM
Even the most basic MIDI songs you can download will have chords and layered sounds which exceed TIA's capabilities, let alone the usual frequency problems. MIDI has 16 channels, but each channel can also have dozens of simultaneous notes. At a minimum, with a MIDI to TIA converter you'd still have a lot of manual refinement to do.
My usual TIA composition process is to start off by creating a piece specifically for the 2600 with Rosegarden and a midi keyboard, manually transpose it to TIA, see what works and what doesn't, and then run through a bunch of iterations until I get something I like.
I suspect the SID conversion works much better because the targeted sound hardware is much closer to TIA than even the most meager GM module is.
#6 SpiceWare OFFLINE
SpiceWare
  • 5,990 posts
  • Medieval Mayhem
Posted Tue Mar 8, 2011 10:05 AM
Could probably utilize DPC+'s 3-Voice Music support (see Demo 1), it comes with the piano's 88 frequencies predefined and you can add other frequencies if you need them. I don't know if it'll be useable in bB though.
Edited by SpiceWare, Tue Mar 8, 2011 10:08 AM.
#7 theloon OFFLINE
theloon
  • 1,015 posts
Posted Tue Mar 8, 2011 1:52 PM
I wonder if someone could convince the 1 track MIDI converter to release his little utility? Even one track is better than, er, none. For me the object is not to convert existing MIDI files but create them in a composition program. I can deal with using 1 track in a comfortable music editor and then convert it with that tool.
#8 Pong OFFLINE
Pong
    Chopper Commander
  • 172 posts
Posted Tue Mar 15, 2011 8:57 AM
It's extremely easy for me to make my songs into only one channel- I had drums which were cut out of the final product, so I have only one channel left.
#9 batari OFFLINE
batari
    )66]U('=I;B$*
  • 6,236 posts
  • begin 644 contest
Posted Fri Mar 18, 2011 8:12 PM
If he sees this thread, maybe... But anyway, if you post your MIDI, I'll run it through the converter.
#10 Pong OFFLINE
Pong
    Chopper Commander
  • 172 posts
Posted Sun Mar 20, 2011 9:14 AM
I'll post it later.
I have a question about the converter, though- does it read note lengths right, tempo right, velocities, and notes right (songs tend to be from C2-C8, FL Studio scale)
#11 batari OFFLINE
batari
    )66]U('=I;B$*
  • 6,236 posts
  • begin 644 contest
Posted Mon Mar 21, 2011 11:20 AM
I'll post it later.
I have no clue, but I'd be surprised if it did all that.
#12 yuppicide OFFLINE
yuppicide
    I am the Black Knight. Give me your money!
  • 6,933 posts
Posted Sun Apr 10, 2011 9:35 PM
Here's some SID2TIA loops I did that came out decent if you want to hear:
http://www.atariage....ost__p__1784406
