left difficulty switch A - level editor
left difficulty switch B - level select
select a level with the select switch.
To start a game, press fire.
In the level editor: To turn a square off or on, select a square with a cursor and press fire.
Not in the level editor: To select a square, use the cursor and press fire and normal Lights Out rules will apply.
To exit the level editor and try to solve the puzzle you've created, press reset switch.
To reset the level you're on to try again, press the reset switch.
Once you've finished the puzzle, it moves on to the next level. There are 5 levels put in so far so if you pass level 5, nothing will happen.
Also, if someone can test this on a real 2600, I would appreciate it.
