The other night I was running my main 800xl machine switching back and forth between the hard disk and the MyIDE+FLASH setup doing some connection tests to my BBS when a strange thing happened. I had the MYIDE plugged in and booted to a partition on my CF card and was checking some things on the emulator running on the PC when I heard a strange noise coming from the 800xl. The screen was doing something really weird (Purplish bands across it). I immediately shut it down and pulled the MyIDE+Flash cart out. The CF card plugged in here was so hot it burned me and a small hole about 1mm in diameter was burned into the front of it... strange. I waited a few minutes and rebooted to check the card - partition 1 booted up and appeared fine but I am sure some of the other partitions are toast - obviously some memory has burned up.
At any rate, I shut it down and didn't mess with it anymore until this morning when the first thing I did was the check the power supply to the 800xl. I pulled it out of the tray where it has been sitting since 2007. Sure enough, the Multi-meter revealed it was putting out 6.3 volts. Cut the leads off to save them and threw the brick in the trash. Plugged in another one and ready to go.
I was lucky... the 6.3 volts was not enough to mess up the 800xl. I suspect I need a new CF card.
Moral of the story... check your power supplies!! I could happen to you and you might not be so lucky...
