ColecoFan1981, on Mon May 9, 2011 3:39 AM, said:
How do code this ASM to make a longer title, one on two or three lines? For example: "PRESENTS NINTENDO'S DONKEY KONG" (on two lines)?
~Ben
~Ben
cv labels and default cartridge header.zip 6.7K
43 downloadsNote : This file can be used as a template for those who like to code from scratch and would like to use the ColecoVision BIOS calls in their projects.
Description : I've made a zip file with the essential labels for getting started (sort of) with CV asm coding. It's just 3 versions of the same thing : a list of the official labels from the Coleco Industries documentation and a default Coleco cartridge header ready to be modified by you. There is 3 versions of the same file because I've tried 3 different Z80 assemblers and none of them can compile the same source code because they use different syntax and keywords. Anyway, hope you someone find this useful.
Z80 assemblers used : tniasm, pasmo, sjasm
Note: I've tried KAsm, a Z80 assembler written in Java, but I can't find a way to make it generates files that start at $8000 instead of $0000, except if I modify the source code or cut the first 32KB of void manually which is annoying.
As usual, let me know if you find this useful by leaving a comment and "rating this topic".
And for those who just want to see a list of labels...
AMERICA @ $0069
AMERICA value (in decimal) is either 60 (NTSC) or 50 (PAL)
ASCII_TABLE @ $006A
ASCII_TABLE is the pointer to where the uppercase ASCII pattern starts.
NUMBER_TABLE @ $006C
NUMBER_TABLE is the pointer to the numbers 0-9 font, not the entire ASCII font.
DECLSN @ $0190
Decrement low nibble (in UTILITY)
DECMSN @ $019B
Decrement high nibble (in UTILITY)
MSNTOLSN @ $01A6
Copy high nibble to low nibble (in UTILITY)
ADD816 @ $01B1
Add signed 8bit value A to 16bit. HL := HL + A
LEAVE_EFFECT @ $01D5
Called by a special sound effect function when done
PX_TO_PTRN_POS @ $07E8
Pixel to pattern plane position
PUT_FRAME @ $080B
Copy a block of names to VRAM
GET_BKGRND @ $0898
Copy a block of names from VRAM to RAM
CALC_OFFSET @ $08C0
Returns DE := offset for the coordinates (E,D) for a 32x24 chars screen.
And so on, there are many more official Coleco BIOS symbols and calls you can use.
Edited by newcoleco, Thu May 12, 2011 9:55 AM.
