0
PLEASE HELP ME IM FEEL VERY BAAAD
23 replies to this topic
#1 jakAtariTech OFFLINE
jakAtariTech
    Space Invader
  • 11 posts
Posted Thu May 26, 2011 11:56 AM
Hello for all, i buy a atari jaguar and atari jaguar cd on ebay, but i dont can do work jaguar cd,
the jaguar base whith cartridge are good
the jaguar cd with cartridge are good too
but when i power on without cartridge only with cd , always see the same picture of back to console and NO POWER, but i use the originals official power supply!!
i open totally console, clean contact intern and extern of jaguar and jaguar cd, i check all , but I CANT FIX THIS!!!!!! PLEASE HELP MEEEEE I PAY 300$ and i feel VERY BAD!!!
plese help me!!!!! atach image of my error!!
Edited by jakAtariTech, Thu May 26, 2011 11:58 AM.
#2 sh3-rg OFFLINE
sh3-rg
    Dragonstomper
  • 626 posts
Posted Thu May 26, 2011 12:08 PM
Have you tried powering the Jaguar on its own with just the power pack form the jag CD?
#3 the.golden.ax ONLINE
the.golden.ax
    Toss me
  • 10,350 posts
  • Just don't tell the Elf
Posted Thu May 26, 2011 12:10 PM
One of your power supplies is either not working or not giving enough power to the CD drive. Try switching the power cords from one unit to the other. If the Jaguar will not boot up with both of the power supplies you may need a new one.
AX
#4 jakAtariTech OFFLINE
jakAtariTech
    Space Invader
  • 11 posts
Posted Thu May 26, 2011 1:04 PM
hello , in first say thanks very much for help me to fast!!!
i try conect just jaguar cd but in this mode atari jaguar base led not light and dont work
the jaguar adapters are totally functionally (i have 3 official power supply) , and the 3 adapters are work into the base console but non workin into jag cd
:( :( :( any solutions??? thaaaaaaaaaaaaaaaaaaaaaaaaaaaanksss
Edited by jakAtariTech, Thu May 26, 2011 1:05 PM.
#5 BuddyBuddies OFFLINE
BuddyBuddies
  • 2,194 posts
Posted Thu May 26, 2011 1:56 PM
there has to be a game in the Jaguar console for the power to come on, not sure if you knew that already. Good luck
#6 jakAtariTech OFFLINE
jakAtariTech
    Space Invader
  • 11 posts
Posted Thu May 26, 2011 2:15 PM
hello when you use a cd in jaguar cd dont can put any cartridge because if you put any cartridge the consolo run a cartridge non cd game, :( i need good luck!!!!!!!!!!!!!!!!
thanks al lot friend for your solution but my jaguar problem dont fix!!! thaaaanks
#7 WIZZARD77 OFFLINE
WIZZARD77
    Chopper Commander
  • 133 posts
Posted Thu May 26, 2011 2:44 PM
Check the solder points for the power connector on the JagCD board. Could just be a bad connection there.
#8 jakAtariTech OFFLINE
jakAtariTech
    Space Invader
  • 11 posts
Posted Thu May 26, 2011 2:59 PM
hello, this point are test with my tester :(
anybody have this problem??? im Alone whit this problem??? unbelive!!!
but thanks very much,
i try whit power supllpy with more amper and dont work :(
Edited by jakAtariTech, Thu May 26, 2011 3:00 PM.
#9 the.golden.ax ONLINE
the.golden.ax
    Toss me
  • 10,350 posts
Posted Thu May 26, 2011 3:22 PM
Make sure it has the correct polarity.
AX
#10 jakAtariTech OFFLINE
jakAtariTech
    Space Invader
  • 11 posts
Posted Thu May 26, 2011 3:28 PM
AX
yes its a correct polarity, its a official power supply!! thanks
#11 busterm OFFLINE
busterm
    Moonsweeper
  • 479 posts
Posted Thu May 26, 2011 5:20 PM
Ive had this happen a few times on some Jaguar CD's I've refurbished most of the time the CD motor on the Transponder is burned out or one of the solder points on the transpond motor or laser has come loose. You will notice there are small cables that go with it.
That icon you see means power isnt being received by one of the Jaguar CD components not just the Jaguar CD itself.
Edited by busterm, Thu May 26, 2011 5:21 PM.
#12 jakAtariTech OFFLINE
jakAtariTech
    Space Invader
  • 11 posts
Posted Thu May 26, 2011 6:03 PM
hello, when i put the laser in the up zone (with my hands) and power on the console, this motor are ok and go a laser down, is this possible with cd motor broken??? i check every point of solder of a len and motor and i dont see any damage point, what point are you think maybe damage, i can try check again this point, thanks a lot friend.
#13 the.golden.ax ONLINE
the.golden.ax
    Toss me
  • 10,350 posts
Posted Thu May 26, 2011 6:07 PM
AX
I meant when you try a power supply with more mAh
AX
#14 busterm OFFLINE
busterm
    Moonsweeper
  • 479 posts
Posted Thu May 26, 2011 6:28 PM
Their are two motors
one turns the cd which is the one that goes out the most often and the second smaller one that moves the laser back and forth
#15 jakAtariTech OFFLINE
jakAtariTech
    Space Invader
  • 11 posts
Posted Thu May 26, 2011 6:34 PM
i try with a universal adapter with 2000 mha and nothing !!!
i check wires of two motors and i cant see any broken wire or anything bad!! pfff :(
#16 jakAtariTech OFFLINE
jakAtariTech
    Space Invader
  • 11 posts
Posted Thu May 26, 2011 6:50 PM
i take a photos
Edited by jakAtariTech, Thu May 26, 2011 6:53 PM.
#17 FABombjoy OFFLINE
FABombjoy
    Moonsweeper
  • 404 posts
Posted Fri May 27, 2011 10:58 AM
I've also seen that screen come up when there is a bad connection on the cartridge interconnect board in the Jag CD unit. Twice, actually. Removing, cleaning, and reseating that board fixed it both times.
#18 JagChris ONLINE
JagChris
  • 1,594 posts
Posted Fri May 27, 2011 11:06 AM
Something the actual Jaguar CD lid doesnt seat right on that little switch that is suppose to let it know the CD lid is closed. Close the Jag CD lid and try making sure it is seated securely. Or hold the switch down manually and see if that is the problem.
#19 jakAtariTech OFFLINE
jakAtariTech
    Space Invader
  • 11 posts
Posted Fri May 27, 2011 12:20 PM
the cartridge pin an every pins conector intern an extern are cleaned, the switch you say jagchris are good i tested this whith a tester, i hold the swith of cd open and dont worry, pfffff :( thanks friends
#20 jakAtariTech OFFLINE
jakAtariTech
    Space Invader
  • 11 posts
Posted Fri May 27, 2011 12:32 PM
can this problem of this??? how i test this??
#21 JagChris ONLINE
JagChris
  • 1,594 posts
Posted Fri May 27, 2011 12:35 PM
ok just trying to cover all bases. :)
#22 JagChris ONLINE
JagChris
  • 1,594 posts
Posted Fri May 27, 2011 12:37 PM
When you post stuff like this you might want to take a moment with MS Paint or somesuch and circle the actual area you are specifically curious about. All we see is a long splaying circuitboard.
#23 jakAtariTech OFFLINE
jakAtariTech
    Space Invader
  • 11 posts
Posted Fri May 27, 2011 8:45 PM
ok, sorry , this regulators
#24 busterm OFFLINE
busterm
    Moonsweeper
  • 479 posts
Posted Fri May 27, 2011 9:12 PM
From the photo they look fine. As for the motors you wont know if they are dead or not till you supply power to them. If the CD lens moves back and forth when you power on the Jaguar but the cd spindle motor does not move then the motor for the spindle is confirmed dead.
