Posted Sat May 28, 2011 2:28 AM
Posted Sat May 28, 2011 4:27 AM
Posted Sat May 28, 2011 9:22 AM
Posted Sat May 28, 2011 11:09 AM
jwierer, on Sat May 28, 2011 9:22 AM, said:
libgluezilla not found. To have webbrowser support, you need libgluezilla installed Unhandled Exception: System.InvalidOperationException: WinForms_SeeInnerException ---> System.NullReferenceException: Object reference not set to an instance of an object at System.Windows.Forms.WebBrowser.Navigate (System.Uri url) [0x00000] in <filename unknown>:0and so on. The "libgluezilla" library is for internal browser support and there is no libgluezilla port for OSX right now (and it's not clear if there will be anytime soon.) I'd guess that the references to the browser would need to be removed for it to work.
Posted Sat May 28, 2011 12:32 PM
Posted Sat May 28, 2011 2:52 PM
Posted Sun May 29, 2011 10:17 AM
Posted Sun May 29, 2011 11:36 AM
Posted Mon May 30, 2011 7:11 AM
Posted Mon May 30, 2011 11:48 AM
Posted Mon May 30, 2011 7:10 PM
Posted Mon May 30, 2011 7:23 PM
[esplonky@Esplonky visualbb]$ mono VisualbB.exe
** (VisualbB.exe:17774): WARNING **: The following assembly referenced from /home/esplonky/Desktop/visualbb/VisualbB.exe could not be loaded:
Assembly: Microsoft.VisualBasic (assemblyref_index=1)
Version: 8.0.0.0
Public Key: b03f5f7f11d50a3a
The assembly was not found in the Global Assembly Cache, a path listed in the MONO_PATH environment variable, or in the location of the executing assembly (/home/esplonky/Desktop/visualbb/).
** (VisualbB.exe:17774): WARNING **: Could not load file or assembly 'Microsoft.VisualBasic, Version=8.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies.
The entry point method could not be loaded
Posted Tue May 31, 2011 12:18 PM
Posted Sat Jun 4, 2011 5:19 PM
Posted Sun Jun 5, 2011 3:43 PM
esplonky, on Sat Jun 4, 2011 5:19 PM, said:
Posted Sun Jun 12, 2011 12:15 PM
Posted Sun Jun 12, 2011 12:17 PM
Posted Sun Jun 12, 2011 12:24 PM
Can't install /tmp/mono-basic-2.6.2-1.fc14.i686-1.rpm as no transaction
Posted Sun Jun 12, 2011 2:02 PM
