I have had many people ask me if theres any way to make the MIO's on-board RAM nonvolatile. One popular use for the MIO's onboard memory has alwayse been to store often accessed files, config data, often loaded executables, etc. In a BBS scenario, this can make the board substantially faster, while reducing wear & tear on physical drives. Only problem is that if power fails, you loose it.
Here is a UPS that I found that is perfect for the MIO. It's made to provide backup power to residential internet gateways, routers, and IP telephony equipment.
http://www.belkin.com/gatewaybattery/
http://en-us-support...ct/detail/p/667
YOu can pick them up relatively cheap on Ebay or Amazon. It plugs directly into the MIO, and takes the place of the "power brick" you would normally use.
It has a trap-door in the back to easily replace the sealed lead-acid battery, which is a very common type that can be purchased from a multitude of vendors for $15-$17US...
I have one here that I just picked up at a thrift store for $10.00, and according to the built in diagnostics, the battery is good.
I just brought it home and plugged it directly into the MIO (it has the right connector on it), and it powers the MIO just fine, with or without AC power.
It has built in battery diagnostics/health/level monitoring, and an audible alarm that sounds when power fails. Theres a switch right on the front to permanently disable the alarm, which is a GREAT feature, if you have intermittant power service.
