HandyMusic
42 replies to this topic
#1 TailChao OFFLINE
TailChao
    Moonsweeper
  • 348 posts
  • Jaja.
Posted Sat Jul 16, 2011 12:57 PM
Hi all,
I've been using this sound driver for my projects for a little over a year now. I was going to wait until I had a good tracker working or at least a sound script compiler, but I have not had much free time to work on these things. So I am releasing the driver and auditioning software now in case anyone wants to try and use it (or at least learn from it), and hopefully I will be able to finish some PC-side composition tools to make life easier.
The driver itself is based upon macro instruments, so instruments are simply sound effects played with a frequency offset. This allows you to get much more complex envelopes than just ADSR. Stereo panning and attenuation is supported, as is streaming of small samples from the cart. The driver is not very large and expects to live in $A000-$A6AF, and uses $A6B0-$BFFFF for sound effects and music data.
If anyone would like to try using the driver, or hear a demo, things have been uploaded here.
Enjoy.
#2 sage OFFLINE
sage
    Moonsweeper
  • 391 posts
Posted Sat Jul 16, 2011 1:31 PM
Well thats good that there are now several music tools for usage available. Bad only nobody wants to use them :-b
Hear some test here: http://lynx.syntaxparty.org/tests/
Or if you have a flashcart:
lynxdev.atari.org/flashcart_slideshow.lnx
#3 TailChao OFFLINE
TailChao
    Moonsweeper
  • 348 posts
  • Jaja.
Posted Sat Jul 16, 2011 1:53 PM
As long as the tools eventually get good enough for people to move away from ugly sounding MODs, that's all I care. Lynx stuff is so behind NES in terms of tools that are actually usable in games.
Waveform preview in your music suite is a nice idea, by the by :)
#4 sage OFFLINE
sage
    Moonsweeper
  • 391 posts
Posted Fri Aug 26, 2011 2:30 PM
I tried to play a bit with your engine, but I have a problem converting actual notes to the values which your driver accepps. at least it seems what it plays is not want I wanted it too.
Maybe you can help by providing the function which you used to convert a note (=frequency) into your 16.8 format
#5 TailChao OFFLINE
TailChao
    Moonsweeper
  • 348 posts
  • Jaja.
Posted Sat Aug 27, 2011 1:00 AM
Sorry things are a bit vague with no PC tools finished yet, but it is something like this in the software:
F= Desired Frequency
p= Number of Poly Counter clocks for one full period of the waveform (example : 2 for a 50% duty cycle pulse using feedback setting $01, 3 for a 33% duty cycle pulse using feedback setting $3)
Fp = F*p;
if(Fp > 1000000.0) div = 0;
else if(Fp > 3906.25) div = (1000000/Fp)-1;
else if(Fp > 1953.13) div = (500000/Fp)+128;
else if(Fp > 976.563) div = (250000/Fp)+256;
else if(Fp > 488.281) div = (125000/Fp)+384;
else if(Fp > 244.141) div = (62500/Fp)+512;
else if(Fp > 122.07) div = (31250/Fp)+640;
else if(Fp > 61.0352) div = (15625/Fp)+768;
else div = 1023;
Where "div" is your frequency value for HandyMusic used in bits 0-9 in the 16.8 format. Decimal is used only internally, and top bits are ignored (so things will wrap around).
I hope this helps.
#6 sage OFFLINE
sage
    Moonsweeper
  • 391 posts
Posted Sat Aug 27, 2011 11:20 AM
I hope this helps.
Yes it did.
Other thing:
In an instrument script, is the first command in the script parsed at time zero or one after note on?
#7 TailChao OFFLINE
TailChao
    Moonsweeper
  • 348 posts
  • Jaja.
Posted Sat Aug 27, 2011 1:00 PM
View Postsage, on Sat Aug 27, 2011 11:20 AM, said:
Other thing:
The first command in an instrument script is processed one frame after the music script's note on. But the channel in hardware is not turned on until this time as well, so there is no distortion from setting things the previous frame.
#8 sage OFFLINE
sage
    Moonsweeper
  • 391 posts
Posted Sat Aug 27, 2011 3:21 PM
Other thing:
O.k. thus setting the volume in the header has no effect if the first command is a change volume command, right?
#9 TailChao OFFLINE
TailChao
    Moonsweeper
  • 348 posts
  • Jaja.
Posted Sat Aug 27, 2011 4:08 PM
Yes, exactly. So crazy things can be done with that if needed.
#10 sage OFFLINE
sage
    Moonsweeper
  • 391 posts
Posted Sun Aug 28, 2011 1:41 AM
Good.
Now I need to change the replay frequency.
Are there any traps or is it enought to move the player to another timer?
Next: I need more space for the music, can I (in your example programm) just change the adresses or will that have some side effects?
#11 sage OFFLINE
sage
    Moonsweeper
  • 391 posts
Posted Sun Aug 28, 2011 1:54 AM
Ah, and will an "embedded" delay of 0 wait for 0 or 256 ticks?
#12 TailChao OFFLINE
TailChao
    Moonsweeper
  • 348 posts
  • Jaja.
Posted Sun Aug 28, 2011 2:15 AM
The only thing HandyMusic reserves is Timer 3 for sample playback on channel 0. The driver can be called from wherever you like. I did some tests at 120Hz and 240Hz and it seemed fine with it. 60Hz is used as the default since it's adequate for most game music without crazy arpeggios.
As for moving the music to a different address, just change the line :
HandyMusic_Song_BaseAddress	EQU $B000
In the top of HandyMusic/HandyMusic.asm to some free region and it should work. $200+ should be open. All of the music decoding is done with ZP-indirect addressing, so it should be fine.
A delay of zero will be skipped (0). But if you need really long delays, you can just use loops in your instruments or music. Loops can be four-deep, so there's no real heavy restrictions.
#13 sage OFFLINE
sage
    Moonsweeper
  • 391 posts
Posted Sun Aug 28, 2011 5:10 AM
Thanks for the information.
Seems I have understood most of it -> see PM
If I look in your code, you reset the Timer every tick, even so the replay freq has not changed, which disturbes the freq a bit.
#14 TailChao OFFLINE
TailChao
    Moonsweeper
  • 348 posts
  • Jaja.
Posted Sun Aug 28, 2011 11:38 AM
It certainly sounds like you figured it out. Those examples are really great!
Yes, this did not seem to cause too many problems to my ears. But I am not the best with music, so I'll add a check for it in the next version. There are some things to fix in samples anyway.
#15 sage OFFLINE
sage
    Moonsweeper
  • 391 posts
Posted Mon Sep 5, 2011 5:39 PM
I have some more wishes for a future version ;-)
Call Pattern/Return would be one of them
#16 TailChao OFFLINE
TailChao
    Moonsweeper
  • 348 posts
  • Jaja.
Posted Wed Sep 14, 2011 4:02 PM
Added in v1.2 (hastily). No compatibility changes with old MUS/SFX data or driver use, and not many other changes in general. Busy working on compiler.
I've also put up gerber files for 2MB Cart PCBs with 2x27C801s, which is what the example program is designed for. You can also get the same banking setup with something like a 29F016 and a NOR gate to combine both cart strobes, and use /CART0 as the high address bit.
#17 rockfistus ONLINE
rockfistus
    Chopper Commander
  • 200 posts
Posted Wed Sep 14, 2011 7:17 PM
View PostTailChao, on Sat Jul 16, 2011 12:57 PM, said:
Hi all,
Enjoy.
I hope the tracker gets finished, I can't wait to bang out some lynx tunes!
#18 sage OFFLINE
sage
    Moonsweeper
  • 391 posts
Posted Sun Sep 25, 2011 3:59 AM
There will be a new version of my unuseable tracker soon, which also supports TailChao driver.
Edited by sage, Sun Sep 25, 2011 3:59 AM.
#19 matashen OFFLINE
matashen
    Moonsweeper
  • 397 posts
Posted Sun Sep 25, 2011 2:50 PM
that would be a great thing, cause i can add simply the driver in c code.
maybe rockfistus can help you to improve chipper.
#20 sage OFFLINE
sage
    Moonsweeper
  • 391 posts
Posted Mon Sep 26, 2011 2:59 AM
updated version at http://lynxdev.atari.org even so not mentioned in the text.
TailChao: I added the updated player code, but seems there is a bug in it ... will send you details later.
Time to write a documentation.... :-/
#21 matashen OFFLINE
matashen
    Moonsweeper
  • 397 posts
Posted Mon Sep 26, 2011 3:33 PM
it dosnt compile
D:\LYNX\sound\chipper (beta)\lynxtc>lyxass handymusic.asm
HandyMusic PCM IRQ Address: $3277
Sound Engine IRQ Address: $3644
HandyMusic Memory left: $3F60
handymusic.asm: 721:ERROR:
Unsolved labels !
whats going wrong?
#22 rockfistus ONLINE
rockfistus
    Chopper Commander
  • 200 posts
Posted Mon Sep 26, 2011 4:27 PM
Playing around with it and making some instruments but it's a bit confusing
#23 sd32 OFFLINE
sd32
    Moonsweeper
  • 285 posts
Posted Mon Sep 26, 2011 8:30 PM
Hey guys, so how good was the Lynx sound hardware compared to the Game Boy and Game Gear? I remember Atari advertising that the Lynx has 32 bit sound, which as usual must just be Atari doing its math thing, hehe.
Some games have really good music, like Lemmings, but other have no music at all, or some terrible compositions. But judging from the games with good soundtracks, i have to say i really like the Lynx music, its pretty unique compared with other systems from its era.
#24 TailChao OFFLINE
TailChao
    Moonsweeper
  • 348 posts
  • Jaja.
Posted Mon Sep 26, 2011 10:29 PM
I will fix things as soon as I figure out what's wrong.
Nice job with the tracker as usual. :)
View Postmatashen, on Mon Sep 26, 2011 3:33 PM, said:
it dosnt compile
Unsolved labels !
whats going wrong?
HandyMusic.asm needs to be added to your own game software, or used with the demo program (HandyAudition). By itself, it's only a library, not a player. If you would like to use HandyAudition, the buildable file in Sage's tracker is "HAud_Knl.asm" in the main folder.
You cannot really pick a best, since it all depends upon what kind of music you'd like to compose. The three work very differently.
GameBoy has very well rounded sound, with two pulse waves, noise, and a small sample channel. I cannot really complain about anything here, Nintendo knew what they were doing. Its big advantages are that little sample channel, different duty cycles on the pulse waves that stay in tune, and a very good frequency range. Sound hardware helps out with some things like sweeps and envelopes as well, to keep the CPU free. The DACs are a bit poor though, only 4-Bit.
Lynx is like an Atari 800 on enhancement pills, you can make some really crazy waveforms. Pulse with different duty cycles, triangles, noise, and other patterns that make no sense can be made on any of the four channels. Advantages here are that all channels in the hardware are identical, which saves some headache. The DACs are also extremely good (8-Bit), giving you great volume envelopes and sample playback (with CPU help). Stereo in the Lynxes that support it is also given a much finer control than both the GB and GG, you get real attenuation. If you want to spend all of your processor time on sound, Lynx can do some really amazing stuff. But for most game scenarios it can keep up with the GameBoy. However, it is much more difficult to work with than both of those two since all your waveforms have different tuning.
Game Gear has three boring square pulses and a similarly boring noise channel. Compared to the other two, there is not much there (and you can really hear the difference in most music). But regardless, I am very impressed with the results many composers got out of this very flat beeper.
In short, the Lynx has a very good, but somewhat complicated noisemaker. I just wish it had twice the channels, since it looks like there's four timer slots unused in the hardware...
Most Lynx games probably leave out sound since it saves money from not having to pay a composer, and keeping a smaller ROM size.
#25 sd32 OFFLINE
sd32
    Moonsweeper
  • 285 posts
Posted Mon Sep 26, 2011 11:13 PM
Damn, thats a great breakdown of the 3 systems audio hardware TailChao, even i understood it, hehe :) , its very interesting. Thanks :thumbsup: .
I have read many times about how weak/boring the SMS/GG soundchip is, but you are right, there are some awesome tracks on their libraries, some that i really love. From Phantasy Star, R Type, Sonic 1, Monster World 3, Golvellius, etc.
Sorry for derailing the thread guys, that was it.
