0
None of the joysticks I have seem to work properly....
10 replies to this topic
#1 lucifershalo OFFLINE
lucifershalo
  • 2,366 posts
Posted Thu Jul 21, 2011 1:03 PM
On Beef Drop I cant go right
On Clowns and Balloons I cant go completely to the right and miss some clowns
other games, the right movements are ok...
Update, I confirm I cant go right in any of the games
three atari 5200 joysticks supposed to be refurbished
but they all have something, start button doesnt work on one
on the second the fire button doesnt operate
and on the 3rd one it is the joystick itself
the trackball is out too
or I am really unlucky with my controllers for 5200 or they are crap
#2 0078265317 OFFLINE
0078265317
    Dragonstomper
  • 765 posts
Posted Thu Jul 21, 2011 3:26 PM
There are x and y sliders on the side. Adjust them.
#3 lucifershalo OFFLINE
lucifershalo
  • 2,366 posts
Posted Thu Jul 21, 2011 3:42 PM
i did
didnt change anything
#4 Jess Ragan OFFLINE
Jess Ragan
    Riding the Crazy Crane
  • 7,951 posts
  • Prepare to Joust... Buzzard Bait!
Posted Thu Jul 21, 2011 3:45 PM
There's also an analog adjustment dial INSIDE the 5200. I've had to adjust it to make the system work properly with some games, particularly Gyruss. Why they didn't put the dial OUTSIDE the system where players could actually reach it is completely beyond me.
#5 lucifershalo OFFLINE
lucifershalo
  • 2,366 posts
Posted Thu Jul 21, 2011 3:47 PM
will have a look
thanks
#6 tz101 OFFLINE
tz101
  • 2,138 posts
Posted Fri Jul 22, 2011 6:23 PM
Pots go bad on the Wico's just like the stock 5200 controllers. I have a pair that both have bad pots and the left-right and up-down movements are bad. I tried the slider adjustments to no avail. The bigger issue is that the Wico pots are special small plastic ones and are not readily available like the ones that Atari put into their controllers. I did find some on a guitar website once, but they were priced around $25 a piece. Ouch, too expensive for me.
#7 lucifershalo OFFLINE
lucifershalo
  • 2,366 posts
Posted Sat Jul 23, 2011 7:39 AM
all of the controllers I have for the 5200 are malfunctioning
I am that close to go into emulation for that console....
so sad :sad:
#8 lucifershalo OFFLINE
lucifershalo
  • 2,366 posts
Posted Sat Jul 23, 2011 7:46 AM
just tried Jr Pac Man and the right movement is working with the Wico controller
why it doesnt work for some games and well for other ones???
#9 tz101 OFFLINE
tz101
  • 2,138 posts
Posted Sat Jul 23, 2011 8:38 AM
5200 is a tricky beast when it comes to calibrating controllers. The first thing is to get a controller that you know the potentiometers are properly calibrated and use it as the baseline to adjust the console pot. You are going to have to open the console case to adjust the controller pot on the motherboard.
Also, make sure you have Missile Command, Super Breakout, Gyruss, and Popeye games handy. IMO those are the big four games for properly calibrating the controller and console pots.
If you have controllers needing refurbished/calibrated and are unsure of how to do it, send them to me and I will make them like new. You will still need to check the console calibration when you get them back, but at least you will have good controllers to work with. The console pot calibration will be easy at that point. It is next to impossible to get this sorted out with both controllers and the console out of calibration.
#10 0078265317 OFFLINE
0078265317
    Dragonstomper
  • 765 posts
Posted Sat Jul 23, 2011 10:01 AM
And btw as for emulation there are no good ones. Tried them all. The only thing that worked was kat5200 and it was buggy. CPU crashes all the time.
#11 Jess Ragan OFFLINE
Jess Ragan
  • 7,951 posts
Posted Sun Jul 24, 2011 1:37 AM
Yeah, emulation is pretty iffy for the 5200. You'd probably be better off buying an adapter for your 5200 so you can use ordinary controllers with a D-shell connector.
