0
Basic case-drilling tips?
9 replies to this topic
#1 Rex Dart OFFLINE
Rex Dart
  • 3,749 posts
  • NO CASH VALUE
Posted Fri Jul 29, 2011 10:35 AM
I was just wondering what methods and tools you guys might use for drilling holes in the plastic shells of old game systems when modding them. I try marking a line on the plastic with a straight edge & drawing cross lines where I plan on drilling, but I'm never fully satisfied with the way the jacks line up once installed. My tools are generally a smallish hand-held power drill, some standard drill bits, spade bits, forstner bits.
I was looking at an A/V mod walkthrough recently & saw some mention of some sort of multi-diameter drill bit. It was conical, stepped, & had different diameters marked all the way to the base. I can't remember the name, but it sounded useful. Anybody use one of those?
Anyways, any tips you can provide would be greatly appreciated.
#2 horseboy OFFLINE
horseboy
  • 1,226 posts
Posted Fri Jul 29, 2011 12:09 PM
I use a really small regular drill bit for a pilot hole and then move on to the forstner bit.
#3 bigbee99 OFFLINE
bigbee99
    Dragonstomper
  • 828 posts
  • Runnin Gunnin
Posted Fri Jul 29, 2011 7:25 PM
I've used these when knocking out metal boxes. They work well.
As far as lining them up, I'd try the pilot hole method after you lay the holes out. It works for me.
B
#4 RevEng OFFLINE
RevEng
  • 2,010 posts
  • bit shoveler
Posted Fri Jul 29, 2011 7:44 PM
Masking tape helps the bit from slipping around and gives you something to make your marks on. The cheaper the better, as the cheap stuff has less adhesive to clean up afterward.
#5 Rex Dart OFFLINE
Rex Dart
  • 3,749 posts
  • NO CASH VALUE
Posted Sun Jul 31, 2011 12:23 PM
Thanks so far; I'll have to try that masking tape trick. Maybe painter's tape? That stuff's about as un-adhesive as it gets.
#6 Rex Dart OFFLINE
Rex Dart
  • 3,749 posts
  • NO CASH VALUE
Posted Mon Aug 1, 2011 9:35 AM
How about part sources / part numbers? Anybody care to list where they prefer to buy transistors, RCA jacks, and the like? I've not been happy with the S-Video jacks I find; they have the wide metal "wings" on either side & I'd rather just have them snap in or bolt in like the RCA jacks.
#7 Chuck D. Head OFFLINE
Chuck D. Head
  • 1,900 posts
  • INTV Illuminati
Posted Mon Aug 1, 2011 10:00 AM
They are called step bits and good ones are $25-35. They make cheap ones ($5-10)which would be fine for plastic, but a few holes in metal and you will feel them getting dull. Another good thing to have is a few countersink bits. If you have a hole where the edges are exposed (a hole for a power LED to poke through the case, for example)the countersink bit can be used to give it a nice beveled edge. Just practice on junk plastic to get the feel of (ie: be smarter than me).
Here are a few online retailers I use for parts and whatnot:
http://www.goldmine-elec.com/
http://www.parts-exp...-components.cfm
Edited by Chuck D. Head, Mon Aug 1, 2011 10:04 AM.
#8 Rex Dart OFFLINE
Rex Dart
  • 3,749 posts
  • NO CASH VALUE
Posted Tue Aug 2, 2011 2:33 PM
So what about drilling holes on "seams" where two halves of a case come together? That's usually what you're looking at when you've got a wide open spot to put A/V jacks, but it seems risky.
#9 Chuck D. Head OFFLINE
Chuck D. Head
  • 1,900 posts
  • INTV Illuminati
Posted Tue Aug 2, 2011 5:41 PM
Tough, but sometimes you gotta. Ideally, what I try to do is secure some kind of sacrificial stock material aver the intended site, lining up a pilot hole through both the stock and where the actual goes. Then use a forstner bit or, if size dictates, some other kind of bit to go through the extra material before you hit the case of your console/ computer. This keeps the edges from mushrooming out, developing ridges, etc - just makes for a cleaner penetration in addition to letting the material guide you through. There might be situations where you would want to drill a full size guide hole through the stock and then affix it in just the right position to drill your case.
#10 Rex Dart OFFLINE
Rex Dart
  • 3,749 posts
  • NO CASH VALUE
Posted Tue Aug 9, 2011 7:19 PM
Well, what I've learned so far...
Digi-Key's pretty good for parts. Got a bunch of connectors for about $1 per part. Cheap shipping.
And something I feel pretty stupid for not coming up with, using the Channel 3/4 switch on a system to switch that RF jack's function from RF to Composite output. Now I've got a sack of worthless yellow jacks. Oh well.
