i'm so f****** sick of this project.
i change 1 thing, and EVERYTHING MESSES UP!!!!!
Here, i was gonna surprise everyone with a fantastic Atari RPG, but the whole dang thing screwed up on me, constantly, throughout the whole project!!!!
and what's worse, is i couldn't understand the errors!!!!
none of them made any sense!!!
if any of you can fix this piece of crap, then by all means, take credit for your huge feat of programming skill.
i'm so fed up with it, and so angry right now.....sorry if my responses seem a bit lashy.....
The controls are as follows:
On the title screen, switchselect starts the game
on the map, joystick 0's directions move you
in battle, left and right selects a kind of attack, and fire gets you into the "action" part of the battle.
you wait until the screen flashes, and press down as fast as you possibly can.
if you do it before the enemy, then you damage the enemy.
if you select the up arrow, or the back arrow, or the shield, your next attack's power is halved, but you have a chance of blocking an enemy's attack
if you select the sword, then you do full damage, but have no chance of dodging/blocking an enemy's attack if they hit you.
your score is your hp.
when you get to a certain map, pressing fire will open a shop screen, where your can buy items.
on the shop, the first 2 digits of the score, is the price of the item
the last 2 are your current money.
left and right changes the selected item.
fire buys and item if you have enough money.
down, exits the shop.
Charaters-
the blue and white guy is "N1"
the red guy is "Pico"
and the yellow bunny girl is "Nyp"
items:
The plant looking thing - An herb, heals 500 hp.
the candy - Has no current use....
The odd red thing(it's supposed to be a crystal), - boosts your attack for 1 battle.
The light blue square - Makes your invincible, lasts until after you're hit once.
the running guy - Allows you to attempt to run from a battle(yes you have to buy that. >:3 )
Note: You have a 50% or so chance to run from a battle.
the guy in a weird pose - Giga command....gives you the effects of a crystal and a square, and doesn't go away when used, but can only be used once per battle
The 2 arrows - Switches characters...you can only do this after you've beaten the boss that nyp has to fight
Bosses will be found on the main maps, not in a random battle.
but they have to be touched in order to enter the battle.
touching a Bed will heal you if your hp is below 100.
the doctor guy near the start of the game doesn't do a thing.
and you're supposed to lose the first boss fight.
after that, you become pico
with pico, going down at his start, then touching the "exit" will send you to the fields....going down 2 more screens, will get you to the boss....
after that, you play as nyp.
she has the same boss location as pico, but the boss will have pico's sprite, indicating he's fighting someone....
but, i have no clue if that even goes that far yet, because of all the bugs appearing from nowhere.
Like if i type "gosub battle_bg1:"
it will give me an error, making me type it like "gosub battle_bg1 :"
and then the background stops working.
completely.
anyways, like i said, i can't fix this within the next few days, then this project is as good as dead.
