Bryan, on Wed Aug 24, 2011 7:02 PM, said:
The smaller brick is for computer use only. The larger brick can be used with either the drives or the computer.
You can buy brand new keyboards on ebay or from places like Best Electronics or B&C Computervisions. Someone here probably has parts. Is the center contact actuator White, Yellow, or Green?
I will try the small brick with the 800, but it seems weird that the drives require more power than the computer itself, especially one with so many chips. On the other hand, the drives have motors that require higher voltages generally than a system.
Guitarman, on Wed Aug 24, 2011 7:07 PM, said:
Your best bet is to get the APE software and an SIO2PC interface. This allows you to load up disk images on a PC and use the PC as a virtual disk drive. I will also allow you to connect, preferably, the 1050 drive to the PC and write the disk images to actual floppies. You can then use the floppies with the drive connected to the Atari. Here is the links to the APE software and SIO2PC interface.
Atarimax Universal SIO2PC/ProSystem interface
Atari Peripheral Emulator (APE)
Okay, I get the idea. However, I have a true IBM PC with a discrete Diskette Drive Controller. The NEC u765 or Intel 8272A on that card can write FM or MFM data. The drives are Tandon TM-100/2A, which can also write FM or MFM data. I even have a Central Point Software Copy II PC Option Board which boasts being able to write Apple II GCR and Atari FM formats. With double density media, I figured there would have to be some solution that did not involve hardware like an SIO2PC.
