0
Colecovision fix?
2 replies to this topic
#1 rawvegandja OFFLINE
rawvegandja
    Combat Commando
  • 1 posts
Posted Tue Aug 30, 2011 9:15 AM
Hello
I just picked up my first Colecovision. The problem is when I turn the console on the character always moves to the left. At first I thought it was a bad controller port or bad controller but I tested the controllers on an Atari and they work reasonably well. I believe the problem is in the console itself because the controller doesn't even have to be plugged in. When I turn the power on the title screen comes up and a few seconds later, the game starts without having press any buttons. If I push the joystick all the way to the right the character will go right, but as soon as I let go It goes back to the left... Has anyone else encountered this problem. More importantly, has anyone been able to fix this problem?
I am not super tech savvy but I have repaired some NES's etc. anyway, I'm willing to give it a shot. After all I can't play it the way it is right now...
At least the power switch is fine and the picture looks really good. Even the expansion module works!
I would greatly appreciate any insights you may have
D
#2 5-11under OFFLINE
5-11under
  • 1,339 posts
Posted Tue Aug 30, 2011 9:31 AM
First of all, welcome to AtariAge.
For DIY, check here: http://www.atariage....ost__p__2018922
If you'd rather someone else do it, contact "Yurkie" in these forums, or find someone local who can do some desoldering and soldering.
#3 gibs OFFLINE
gibs
    Space Invader
  • 16 posts
Posted Thu Sep 1, 2011 6:02 PM
Hi dude,
Easy, it's one or the two SN74LS5541N.
http://www.colecovis...hip replace.pdf
I have some new ones if you want :)
