0
Vice: C64 Emulator Assistance
9 replies to this topic
#1 rmaerz OFFLINE
rmaerz
    Retrocade Magazine Issue 2 Out Now!
  • 6,651 posts
  • \m/
Posted Wed Aug 31, 2011 5:21 PM
I'm using Vice to emulate C64. I can load the games no problem. Problem is I can't start any games because I can't find exactly what keystrokes need to be entered to start a game, set options etc.
#2 stephena OFFLINE
stephena
  • 1,968 posts
  • Stella maintainer
Posted Thu Sep 1, 2011 12:08 PM
Maybe LOAD "*",8,1 and then RUN. It's been a long time since I played with C64 stuff. I think there's an Autostart option when loading a disk image. That is, it attaches the image and basically runs the LOAD/RUN commands for you.
#3 rmaerz OFFLINE
rmaerz
  • 6,651 posts
  • \m/
Posted Thu Sep 1, 2011 1:22 PM
Yeah I use the autostart but once the game loads I have no idea how to start the game
#4 SpiceWare OFFLINE
SpiceWare
  • 5,990 posts
  • Medieval Mayhem
Posted Thu Sep 1, 2011 2:15 PM
that would totally depend on the game. Most of them show something on screen. A lot of them used the F1-F8 keys (normally just the odd numbers as those didn't require holding shift).
Another thing to check is which joystick you're emulating. Most games use the joystick in the 2nd port instead of the 1st port because the 1st port interferes with reading the keyboard.
#5 Desfeek OFFLINE
Desfeek
    Moonsweeper
  • 300 posts
Posted Mon Sep 5, 2011 8:30 PM
Open Vice, Settings > Keyboard Settings > Change from "Positional" to "Symbolic (US)"
It is weird, considering the inconsistencies between contemporary keyboards and the C64 keyboard.
and WHY did they have to emulate the joystick pinout problem? At least it's accurate :)
#6 roadrunner OFFLINE
roadrunner
  • 4,146 posts
  • Da Funkasaurus
Posted Wed Sep 7, 2011 10:19 PM
Is the OP stuck on one of those crack screens?
Try pressing Esc or the space bar or swapping the joystick ports. :)
#7 bigbee99 OFFLINE
bigbee99
    Dragonstomper
  • 828 posts
  • Runnin Gunnin
Posted Fri Sep 9, 2011 8:47 PM
"Caps Lock" is the Run/Stop key. The disk images with the high score savers by "Remember" you have to click the fire button on the joystick, then hit run/stop to start the game. Maybe that will help.
B
#8 cimerians OFFLINE
cimerians
  • 4,453 posts
Posted Wed Sep 14, 2011 8:27 AM
Also, check this thread:
http://www.atariage....-full-of-games/
#9 Zedex OFFLINE
Zedex
    Star Raider
  • 97 posts
Posted Fri Sep 16, 2011 3:10 PM
Today's keyboards have a much different layout than the C64. Maybe you need to set up some options so it's layed out like a real C64. I don't use VICE, I use Power64 on my iMac for C64 emulation. I'm just doing it to get my C64 fix while I'm working on repairing my real C64.
#10 wongojack OFFLINE
wongojack
    Chopper Commander
  • 180 posts
Posted Tue Oct 18, 2011 10:54 AM
Escape is Run Stop for me in Vice otherwise bigbee99 is right on
Press alt+j to swap joystick ports and then try your fire button again
Download a different copy of the disk image
I play tons of images from gamebase64. Most of the time the only keys I need are
L O A D " * " ,8,1
RUN STOP
SPACE
Letter keys are the same for me on a US keyboard
" is shift+2
* is close bracket ]
<above enter next to \>
, is the same
numbers are the same
as mentioned above RUN STOP is escape
+ is - (sometimes used to go through crack instructions)
alt is the same
commodore key is usually the left control key
