Bummer. Colecovision gets the screen garbage problem
9 replies to this topic
#1 Lendorien OFFLINE
Lendorien
  • 1,029 posts
Posted Sun Sep 25, 2011 10:31 PM
Just got a Colocovision at an estate sale. Thing seemed to work fine for a while, but today I plugged it in and got garbage on the screen. The garbage always appears the same, for each game that is put in (meaning, if I put in Centipede and turn on and off the console, every time I turn it on it'll always show the same garbage for that game). I'm pretty sure it's not the power switch issue. Any suggestions?
#2 retroillucid OFFLINE
retroillucid
  • 2,490 posts
  • CollectorVision Games - Publishing Homebrew
Posted Sun Sep 25, 2011 10:56 PM
:lol:
Man! ..... I just can't believe how many of those threads has been started in 2011 !!!
I think we should need to have a thread PNNED ... so everyone who experience CV problem could use that thread
We could all post those infos once for all into the very same thread
Theres just too many users asking for help for their CV system / controllers
#3 Lendorien OFFLINE
Lendorien
  • 1,029 posts
Posted Mon Sep 26, 2011 1:28 AM
That would be a good idea actually. Having one spot with info would be really useful.Perhaps such a thread should be made.
I could also go back and use the search function, but I'm not entirely sure what I'm looking for. I didn't realize it was that common a question.
Edited by Lendorien, Mon Sep 26, 2011 1:30 AM.
#4 rmaerz ONLINE
rmaerz
    Retrocade Magazine Issue 2 Out Now!
  • 6,651 posts
  • \m/
Posted Mon Sep 26, 2011 6:49 AM
Why do you think it is not the power switch?
#5 Yurkie ONLINE
Yurkie
    Q*bert Champion
  • 2,445 posts
  • Offering ColecoVision repairs, refurbs and mods.
Posted Mon Sep 26, 2011 10:55 AM
It is VERY likely the power switch. I remove, clean, refurbish and solder back in place the power switch on every single console I touch. It is too common a problem not to do this.
If your going the DIY route please be careful and have a fair degree of solder and repair skills. Many people ruin ColecoVisions
After power switch this is the order of common problems in my experience
1. cart slot (dirty or bent pins)
2. power plug on back of unit having loose pins/ or power cord being a loose fit. Aside from replacing carefully smashing with channel lock pliers, wrapping electrical tape around the end of the power cord is a fix for this.
3. power supply
4. VDP (video display processor) 40 pin Integrated circuit. If this bad, you may as well look for another CV
5. one usually of the 8 (eight) 4116 DRAM ICs.
6. controller octal buffer IC, Mario jumps or moves automatically in a directions, or cart auto selects a skill level is a tell tale sign.
7. RF board
8. CPU
Other than the power switch I don't recommend a DIY, unless you have a high degree of repair skills. Many people have ruin CVs trying to replace ICs
Power switch is a $20 refurb if you would like me to do it for you. I have done a couple hundred and refurbishing the power switch is just as good as replacing, plus the original looks better.
#6 Lendorien OFFLINE
Lendorien
  • 1,029 posts
Posted Mon Sep 26, 2011 12:59 PM
Well, I don't have a high degree of electronics skills, but the power switch fix is well within my abilities. I have a desoldering iron.
I tried it. buffed the connectors and put in new grease. No dice.
The power plug is pretty tight, so I don't think that's the issue. Any suggestions on diagnosing any of these short of trial and error? I can provide screenshots if needed.
#7 retroillucid OFFLINE
retroillucid
  • 2,490 posts
Posted Mon Sep 26, 2011 1:19 PM
Could it not be the power supply itself?
#8 Yurkie ONLINE
Yurkie
    Q*bert Champion
  • 2,445 posts
Posted Mon Sep 26, 2011 1:32 PM
Probably #3, #4 or #5 on my list. You need a multi-meter and a logic probe at least, unless you want to guess. There are too many variables to do a walk through repair, more than the list I gave you. I would be happy to look at it and give you a free estimate, if you want to send it to me. You really should wear a anti-static wrist strap like the link below when working on any electronics. ESD can cause all kinds or problems.
http://www.amazon.co...ASIN=B000095JBE
#9 Vectorman OFFLINE
Vectorman
    Chopper Commander
  • 108 posts
Posted Tue Sep 27, 2011 11:01 AM
That's what I would suspect. I've owned dozens of Colecovisions over the years and the ones that I initially thought were defective usually worked fine after just swapping the power supply from a different CV. A CV ps that won't work right with one CV will often work fine with another CV. It's odd and they're finicky about PS. Your best option is to forgo those antique, out-of-spec CV ps entirely and buy an arcade machine ps off ebay. They can be had for around $10 and are more stable.
#10 Lendorien OFFLINE
Lendorien
  • 1,029 posts
Posted Thu Sep 29, 2011 9:40 PM
I'll give it a go. It's possible that it is the power supply I suppose. What should I look for exactly?
