Hi folks, A couple months ago my Colecovision started acting weird. Player one is stuck in moving left mode and I believe a fire button is also constantly acting as if pressed on player one. No, it's not the controller, as I've unplugged the controller entirely and it still does it. I've also tried other controllers, and there's no change. So, I thought it must be a problem with the PCB. I also removed the PCB and checked the soldering on the player one joystick port to see if there was a short or a bad solder joint somewhere, but all seems fine. Could something have zapped the board and caused this? BTW, player 2 joystick port is working fine.
Can anybody suggest something else for me to check? if I can't fix this myself, would somebody be able to fix this for me if I send it to you for a reasonable price? I also have another non-working CV I could perhaps trade you in exchange for fixing this one if you're interested...
Please respond to
joe@tillenterprises.com as I don't always check the forums. Thanks!!!
