There are 2 things that happen with the power jack. The cord is either loose fitting or the pins inside the power jack are loose . If the pins aren't too loose, or even if they are you can sometimes get lucky and smash the jack together with a pair of channel locks or a vice. Basically squeezing it together so the plug fits tighter. You can also wrap electrical tape around the plug to increase the size and cause a tighter fit.
You'll have to take the case a part to squeeze the jack.
Take the 8 screws out of the bottom.
Use one hand to pull out on the face plate and the other hand to pry the bottom half away from the top half. The bottom half sits inside the face plate a little, that is why you have to pry out.
Repeat this on the other side.
You will end up with the 2 pieces the top half with face plate attached, and the bottom with the board enclosed in steel shielding.
If you take your time and pry the case a part like this you
NEVER need to remove (ruin) the face plate sticker.
Alternatively I can fix that and get everything working like new and mod it up for you, if your so inclined.
Edited by Yurkie, Fri Oct 14, 2011 7:09 PM.
