Posted Fri Oct 14, 2011 5:38 PM
Posted Fri Oct 14, 2011 5:47 PM
Posted Fri Oct 14, 2011 5:51 PM
Robert M, on Fri Oct 14, 2011 5:47 PM, said:
Posted Sat Oct 15, 2011 4:20 AM
32041 8600 vblk 32042 8600 ; run possible vblank bB code 32043 8600 ifconst vblank_bB_code 32044 8600 20 2a f6 jsr vblank_bB_code 32045 8603 endif 32046 8603 vblk2 32047 8603 ad 84 02 LDA INTIM 32048 8606 30 fb bmi vblk2 32049 8608 4c 00 f1 jmp kernel
Posted Sat Oct 15, 2011 4:33 AM
Posted Sat Oct 15, 2011 4:45 AM
GroovyBee, on Sat Oct 15, 2011 4:33 AM, said:
34297 8cac c4 c4 c4 c4 .byte.b $C4, $C4, $C4, $C4 708 bytes of ROM space left in bank 8 34298 8cac echo " ",[(scoretable - *)]d , "bytes of ROM space left in bank 8") 34299 8cb0 34300 8cb0 34301 8cb0  ; feel free to modify the score graphics - just keep each digit 8 high 34302 8cb0 ; and keep the conditional compilation stuff intact 34303 8cb0 - ifconst ROM2k 34304 8cb0 - ORG $F7AC 34305 8cb0 else 34306 8cb0 ifconst bankswitch 34307 8cb0 - if bankswitch == 8 34308 8cb0 - ORG $2F94-bscode_length 34309 8cb0 - RORG $FF94-bscode_length 34310 8cb0 endif 34311 8cb0 - if bankswitch == 16 34312 8cb0 - ORG $4F94-bscode_length 34313 8cb0 - RORG $FF94-bscode_length 34314 8cb0 endif 34315 8cb0 if bankswitch == 32 34316 8f74 ORG $8F94-bscode_length 34317 8f74 RORG $FF94-bscode_length 34318 8f74 endif 34319 8f74 - else 34320 8f74 - ORG $FF9C 34321 8f74 endif 34322 8f74 endif 34323 8f74 34324 8f74 34325 8f74 scoretable
Posted Sat Oct 15, 2011 5:06 AM
Posted Sat Oct 15, 2011 6:08 AM
Posted Sat Oct 15, 2011 6:11 AM
Posted Sat Oct 15, 2011 6:26 AM
GroovyBee, on Sat Oct 15, 2011 6:11 AM, said:
24313 4e35 echo " ",[(start_bank4 - *)]d , "bytes of ROM space left in bank 4")
24343 4ff2 - echo "WARNING: size parameter in banksw.asm too small - the program probably will not work."
24344 4ff2 - echo "Change to",[(*-begin_bscode+1)&$FF]d,"and try again."
30403 5d86 echo " ",[(start_bank5 - *)]d , "bytes of ROM space left in bank 5")
30433 5ff2 - echo "WARNING: size parameter in banksw.asm too small - the program probably will not work."
30434 5ff2 - echo "Change to",[(*-begin_bscode+1)&$FF]d,"and try again."
30453 6100 echo " ",[(start_bank6 - *)]d , "bytes of ROM space left in bank 6")
30483 6ff2 - echo "WARNING: size parameter in banksw.asm too small - the program probably will not work."
30484 6ff2 - echo "Change to",[(*-begin_bscode+1)&$FF]d,"and try again."
4 718e - ECHO "MACRO ERROR: 'SLEEP': Duration must be > 1"
152 725e ;echo "critical code in 48x1 is ",(pf48x1_codeend-pf48x1_loop), " bytes long."
4 7305 - ECHO "MACRO ERROR: 'SLEEP': Duration must be > 1"
134 7394 ;echo "critical code #1 in 96x2_1 is ",(pf96x2_1_0codeend-pfline_96x2_1_frame0), " bytes long."
4 73ab - ECHO "MACRO ERROR: 'SLEEP': Duration must be > 1"
251 7468 ;echo "critical code #2 in 96x2_1 is ",(pf96x2_1_1codeend-pfline_96x2_1_frame1), " bytes long."
Posted Sat Oct 15, 2011 6:34 AM
Posted Sat Oct 15, 2011 6:45 AM
Posted Sat Oct 15, 2011 6:56 AM
myfile.bas.asm (32046): error: Label mismatch... --> vblk2 f600
Posted Sat Oct 15, 2011 7:05 AM
Posted Sat Oct 15, 2011 7:08 AM
RevEng, on Sat Oct 15, 2011 6:56 AM, said:
Posted Sat Oct 15, 2011 7:28 AM
GroovyBee, on Sat Oct 15, 2011 7:05 AM, said:
Random Terrain, on Sat Oct 15, 2011 7:08 AM, said:
vblk ; run possible vblank bB code ifconst vblank_bB_code jsr vblank_bB_code else nop nop nop endif vblk2
Posted Sat Oct 15, 2011 4:43 PM
Posted Sat Oct 15, 2011 5:09 PM
Random Terrain, on Sat Oct 15, 2011 4:43 PM, said:
Posted Sat Oct 15, 2011 5:20 PM
RevEng, on Sat Oct 15, 2011 5:09 PM, said:
Edited by Random Terrain, Sat Oct 15, 2011 5:20 PM.
Posted Sat Oct 15, 2011 5:36 PM
Posted Thu Oct 20, 2011 9:50 AM
Posted Thu Oct 20, 2011 11:14 AM
atari2600land, on Thu Oct 20, 2011 9:50 AM, said:
Posted Thu Oct 20, 2011 11:17 AM
