How to Lengthen a 3.5mm Audio Cable?
5 replies to this topic
#1 wongojack OFFLINE
wongojack
    Chopper Commander
  • 180 posts
Posted Sun Oct 16, 2011 11:29 AM
I figured someone on here would know this.
I have a VGA cable with an attached audio cable with a 3.5mm connector (like phones). The portion of the audio cable that extends away from the VGA connector is not long enought to reach the phones jack on my laptop. I want to try to patch the cable to make it just a few inches longer.
If I cut the cord (on the audio only) how many wires will I find inside? Is it just right and left? ground? How do I know which is R,L to match them up to another wire that I'll be using for the 'patch'?
#2 SRGilbert OFFLINE
SRGilbert
  • 2,387 posts
Posted Sun Oct 16, 2011 11:54 AM
Why not just get an extention cable? Radiosack should have them cheap enough.
#3 wongojack OFFLINE
wongojack
    Chopper Commander
  • 180 posts
Posted Sun Oct 16, 2011 12:02 PM
Don't want to buy anything else, I have an alternative already, I like to learn things.
I think it would be easy to connect 3 wires and have something exactly the right length.
Someone knows about this and I would be greatful if they would share their knowledge.
#4 Galeforcerm OFFLINE
Galeforcerm
    Chopper Commander
  • 160 posts
Posted Sun Oct 16, 2011 12:59 PM
I have Beverley been able to successfully do it with out getting sound issues. The wires are tiny and the ground is wrapped around the the two wires in the center, like coax cable is. Extensions are cheap. I would just buy one.
#5 nathanallan OFFLINE
nathanallan
  • 5,505 posts
Posted Sun Oct 16, 2011 2:16 PM
Agreed, those wires on the inside are very hard to work with since they are so small; if you just tie them they will oxidize and if you solder them you have a good chance of burning them to unusability. Get a smallish extension cable, save yourself a lot of headache.
#6 wongojack OFFLINE
wongojack
    Chopper Commander
  • 180 posts
Posted Sun Oct 16, 2011 6:04 PM
Thanks for the advice guys - I bought an extension for $5
