Cant COMPILE!?!?! Trouble with visualbb
compile
10 replies to this topic
#1 8bitgnome OFFLINE
8bitgnome
    Space Invader
  • 23 posts
Posted Mon Oct 17, 2011 6:58 PM
HELP. Im sure there are a hundred threads on this, but everthing I hve tried doesnt work. I have batari, visuallbb, visual sound library, stella... I get visual up and running, and If I only hit run.. it will play, but the problems start when I tried to compile. It says it compiles, and then cant locate the bas.bin and could not recompile???????????? or this time it says system path does not include??????. I had this program on an old computer over a year ago wihout problems. But even now I cant use it on my old com, because I even tried loading it on there
I have tried the vb fix and put it into the regedit. Im at a loss. I have tried every fix I could find online. HELP ME OBIWAN YOUR MY ONLY HOPE>>>>>I>>>>>>>>>>>
batari Basic Compiler date (10/17/2011 10:50:06 AM)
Current bB compiler version supports -O option. Peephole optimizer option enabled
Environment variable bB=C:\Users\owner\Desktop\Game maker Master\ATARI MASTER\batari_Basic_version_1.0
Environment variable Path=C:\Program Files\Common Files\Microsoft Shared\Windows Live;C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\QuickTime\QTSystem\;C:\Program Files (x86)\Windows Live\Shared;C:\Users\owner\Desktop\Game maker Master\ATARI MASTER\batari_Basic_version_1.0
[10/17/2011 8:48:16 PM] added project: Tinkernut World
[10/17/2011 8:48:18 PM] Could not locate tinkernut_world.bas.bin. Attempting recompile...
Compile started at 10/17/2011 8:48:18 PM
Compiling C:\Users\owner\Desktop\Game maker Master\ATARI MASTER\tinkernut_world\Tinkernut World\tinkernut_world.bas
[10/17/2011 8:49:18 PM] saving C:\Users\owner\Desktop\Game maker Master\ATARI MASTER\tinkernut_world\Tinkernut World\tinkernut_world.bas succeeded.
Compile started at 10/17/2011 8:49:18 PM
[10/17/2011 8:49:32 PM] Could not locate tinkernut_world.bas.bin. Attempting recompile...
Compile started at 10/17/2011 8:49:32 PM
[10/17/2011 8:49:39 PM] saving C:\Users\owner\Desktop\Game maker Master\ATARI MASTER\tinkernut_world\Tinkernut World\tinkernut_world.bas succeeded.
Compile started at 10/17/2011 8:49:39 PM
#2 iesposta ONLINE
iesposta
    Chopper Commander
  • 177 posts
  • Retro-gaming w/my Lava Lamp
Posted Mon Oct 17, 2011 8:31 PM
http://www.atariage....b/page__st__250
If you want the bleeding edge latest batari basic, the last few pages of this thread helped me out.
However, as of last night visualbb was removed and redownloaded ver (562), and would crash on launch, even after logouts and reboots, but today it runs just fine. Windows (7) will NEVER make sense to me.
Until an installer is created, or things are put in one place, it will be confusing.
I hope others respond.
BTW my Emvironment variable bB is shorter than yours shows. Something like C:\AtariVCS\bB\batari2600.exe BUT my Environment variable Path is HUGE like yours, going into imagicMagic program in program files then windows, win32, etc., on and on, nonsense!
#3 jwierer OFFLINE
jwierer
    Dragonstomper
  • 746 posts
Posted Mon Oct 17, 2011 9:38 PM
[WRONG FORUM MODERATOR PLEASE MOVE]
Usually this is a problem with your installation of bB. What version are you using and did you exact it with the folder structure? The other recommendation is to replace your batch file with this one. The default one tends not to work.
-Jeff
#4 8bitgnome OFFLINE
8bitgnome
    Space Invader
  • 23 posts
Posted Tue Oct 18, 2011 6:31 AM
I hate to ask, but I tried what has been posted here. read the thread from first post, and downloaded files, replaced batch ect..... I dont get it? F it. please walk me through step by step(if you can) to the correct downloads of the most likely to function programs... I never had this problem in the past? I dont understand? Am i putting the wrong paths/ variable locations??? Have I somehow not put the right files together? This is getting REALLLLLLLLLY old fast!!
#5 8bitgnome OFFLINE
8bitgnome
    Space Invader
  • 23 posts
Posted Tue Oct 18, 2011 7:33 AM
Ok I found out that when I try to compile. the .bin gets deleted. i cant find it even with the search function anywhere on my com. I have NO idea why, but I think this is the main problem ive been having?
#6 jwierer OFFLINE
jwierer
    Dragonstomper
  • 746 posts
Posted Tue Oct 18, 2011 9:24 AM
Try compiling from the command-line first to confirm you've actually installed bB correctly.. My guess is it is not ever being compiled because bB isn't installed correctly or you're missing a file. If you post a screenshot of your bB source folder perhaps we can tell. Another thing I noticed is that bB doesn't like path's with spaces and sure enough your path has spaces, "C:\Users\owner\Desktop\Game maker Master\ATARI MASTER\batari_Basic_version_1.0". Do something simple like "c:\atari\bb\". That has been discussed in a number of threads in the past.
-Jeff
#7 8bitgnome OFFLINE
8bitgnome
    Space Invader
  • 23 posts
Posted Tue Oct 18, 2011 6:57 PM
wont let me post screen shot. I did move all files to a shorter, no spaced address in my com. Now i still get deleted bins, and now I get a 16 bit incompatability error? I know i have the right stella? And I assumed i had the right files in place? moved my sed. visual sound dll in same folder as visual.
#8 8bitgnome OFFLINE
8bitgnome
    Space Invader
  • 23 posts
Posted Tue Oct 18, 2011 7:29 PM
I get it to compile now, but the bin still vanishes?
batari Basic Compiler date (10/18/2011 9:17:25 PM)
Environment variable bB=C:\Users\owner\Desktop\bbatari\bB Windows 7
Environment variable Path=C:\Program Files\Common Files\Microsoft Shared\Windows Live;C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\QuickTime\QTSystem\;C:\Program Files (x86)\Windows Live\Shared;C:\Users\owner\Desktop\bbatari\bB Windows 7
[10/18/2011 9:27:25 PM] added project: Tinkernut World
[10/18/2011 9:27:28 PM] Could not locate tinkernut_world.bas.bin. Attempting recompile...
Compile started at 10/18/2011 9:27:28 PM
Compiling C:\Users\owner\Desktop\bbatari\tinkernut_world\Tinkernut World\tinkernut_world.bas
2600 Basic compilation completed.
Compile started at 10/18/2011 9:27:50 PM
[10/18/2011 9:27:51 PM] Could not locate tinkernut_world.bas.bin. Attempting recompile...
Compile started at 10/18/2011 9:27:51 PM
#9 ScumSoft OFFLINE
ScumSoft
    Moonsweeper
  • 331 posts
Posted Tue Oct 18, 2011 7:52 PM
Remove any spaces from the path name and try again.
#10 jwierer OFFLINE
jwierer
    Dragonstomper
  • 746 posts
Posted Tue Oct 18, 2011 8:04 PM
It's actually not compiling, it's just telling you it's done trying to compile. If it was actually compilng you'd see DASM outputs. Please see my previous post and follow that advice first.
#11 8bitgnome OFFLINE
8bitgnome
    Space Invader
  • 23 posts
Posted Wed Oct 19, 2011 6:24 AM
THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU, and oh yeah THANK YOU!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! If you didnt take the time to help me I would never had gotten this to work. Thank you again. Now I can begin making the worst game for atari ever lol, butit will be my bad game.
