0
Dectect Press Lightgun Trigger
lightgun
1 reply to this topic
#1 Primordial Ooze OFFLINE
Primordial Ooze
    Dragonstomper
  • 504 posts
  • Quacker Blaster Lead Programmer
Posted Wed Oct 19, 2011 6:21 PM
Hi,
I am trying to get the screen to flash when the trigger on the lightgun is pressed. I tried the following:
lda INPT5                           	    ; a 0 in bit D4 means the fire button was pressed
bmi SkipCheckFire                     ; if the fire button wasn't pressed then jump to SkipCheckFire
lda #$01
sta FlashState						    ; set gun barrel anaimation to true
lda WHITE
sta COLUBK							   ; set the background color to white
SkipCheckFire
However it only works when the fire button is pressed on a joystick controller. Does anyone know how to check if the fire trigger was pressed on a lightgun?
Sincerely,
Primordial Ooze
#2 GroovyBee OFFLINE
GroovyBee
    7800 Developer
  • 5,782 posts
  • Busy bee!
Posted Thu Oct 20, 2011 2:41 AM
Did you look at the link I posted here :-
http://www.atariage....ost__p__2363180
