This will only identify bad DRAM that are fully non-functional, though most DRAM do fail that way. Bad/missing DRAM will show a red bar, working ones a green bar.
The u# shown on the screen are for the 4-port 5200. I don't have a schematic of the 2-port model handy to see if they have different PCB markings.
The ROM attached is a standard 32K binary. You can use any type of reproduction board to make a cart. If you can't make a cart yourself Albert may still make them, or you can PM me and I will try to find time to make a few.
You can load this from the Ultimate SD menu, but the Ultimate SD already requires working RAM, so running it from there is not possible on a system with bad ram. For those cases I have attached a specially packed core_boot.rom that can be used to replace the Ultimate SD standard boot rom. This requires re-flashing your SD cart back to the standard boot rom after use. More information is in the "readme_first.txt" file in the archive about this procedure.
If this program fails to run on the non-working 5200 console then the problem is probably bigger than just a bad RAM IC and you can start looking more deeply for other issues.
Steve
