Chuck D. Head Posted October 29, 2011 Share Posted October 29, 2011 Trying to install my Aquaricart upgrade and I cant get the donor cart open, what gives? I see two holes that looked like they might release something and what looked like little tabs inside the open end of cart but neither seems to yield any results. Help!! Quote Link to comment Share on other sites More sharing options...
jaybird3rd Posted October 29, 2011 Share Posted October 29, 2011 Aquarius cartridges with no screws are held together with plastic pins. The easiest way to get them open is to pop the back door off by twisting it open with a coin (a nickel is the perfect thickness). Just insert the edge of the coin into the notches at the top corners and twist: (This may be obvious, but when you install the Aquaricart board, insert it with the chips facing the inside of the cartridge shell. Slide the finger edge of the board into the slot at the bottom, and then line up the guide holes with the plastic teeth inside the shell. There will be two more plastic teeth "biting" into the other guide holes from the back side when you put the door back on.) Quote Link to comment Share on other sites More sharing options...
Chuck D. Head Posted October 29, 2011 Author Share Posted October 29, 2011 Thanks Jay! I might have known it was that easy. Aquaricart is fantastic!!! :lust: :lust: Thanks so much for all your hard work. 1 Quote Link to comment Share on other sites More sharing options...
