Posted Sun Oct 30, 2011 9:17 AM
Posted Sun Oct 30, 2011 5:14 PM
set tv ntsc const noscore = 1 set kernel_options pfcolors no_blank_lines include multisprite_kernel.asm include multisprite.h set kernel multisprite set romsize 4k
[root@xxx/xxxx/xxxx/xxxx]# make 2600basic.sh default.bas -O Starting build of default.bas 2600 Basic compilation complete. DASM V2.20.09, Macro Assembler (C)1988-2003 fs length $85 --> FineAdjustTableBegin f000 default.bas.asm (1199): error: EQU: Value mismatch. old value: $ef0f new value: $f35b default.bas.asm (1434): error: Branch out of range (-1095 bytes). default.bas.asm (1652): error: Branch out of range (-1046 bytes). default.bas.asm (1906): error: Branch out of range (-1095 bytes). default.bas.asm (1917): error: Branch out of range (-1094 bytes). default.bas.asm (2210): error: Branch out of range (-1092 bytes). Build complete. \n >:( >:( >:( Compile of default.bas FAILED! >:( >:( >:(\n
Posted Tue Nov 1, 2011 1:33 AM
Posted Tue Nov 1, 2011 5:51 AM
set tv ntsc const noscore = 1 include multisprite_kernel.asm includes multisprite.h set kernel multisprite set romsize 4k
[root@xxxx/xxxx/xxxx/xxxx/xx]# make 2600basic.sh default.bas -O Starting build of default.bas 2600 Basic compilation complete. DASM V2.20.09, Macro Assembler (C)1988-2003 fs length $85 --> FineAdjustTableBegin f000 default.bas.asm (1199): error: EQU: Value mismatch. old value: $ef0f new value: $f35b default.bas.asm (1434): error: Branch out of range (-1095 bytes). default.bas.asm (1652): error: Branch out of range (-1046 bytes). default.bas.asm (1906): error: Branch out of range (-1095 bytes). default.bas.asm (1917): error: Branch out of range (-1094 bytes). default.bas.asm (2210): error: Branch out of range (-1092 bytes). Build complete. \n >:( >:( >:( Compile of default.bas FAILED! >:( >:( >:(\n
Posted Tue Nov 1, 2011 8:28 PM
includesfile multisprite_superchip.inc set kernel multisprite set tv ntsc set romsize 8kSC set smartbranching on
Edited by ScumSoft, Tue Nov 1, 2011 8:29 PM.
Posted Tue Nov 1, 2011 8:44 PM
const noscore = 1 includesfile multisprite.inc set kernel multisprite set romsize 4k set tv ntsc set smartbranching on
Posted Tue Nov 1, 2011 9:05 PM
multisprite.h.txt 2.74K
16 downloadsPosted Tue Nov 1, 2011 9:39 PM
Posted Wed Nov 2, 2011 3:24 AM
Posted Wed Nov 2, 2011 6:00 AM
