I opened it and cleaned the contacts (under the rubber caps plus the circuit board) and it worked for a day or two and now doesn't work again. Even shorting the button circuit board with a screwdriver tip doesn't work.
Before I start desoldering/soldering all connections are there any known issues with this controllers? Anywhere I should check before I pull it apart again?
Thanks
