343 Scanlines Why?
52 replies to this topic
#1 Primordial Ooze OFFLINE
Primordial Ooze
    Dragonstomper
  • 504 posts
  • Quacker Blaster Lead Programmer
Posted Tue Dec 13, 2011 1:34 PM
Hi,
I just finished adding the crosshair sprite into the game and am having difficulties. For some reason when i added the code for the crosshairs, my scanline count went up to 343 which is way too high. I figured it had something to do with the lightgun detection code and disabled the call to the routine, except my scanline count remained the same at 343. I can't see how displaying 2 sprites will cause the scanline count to jump to 343. I have attached the latest version of the source code for reference. Any assistance would be greatly appreciated.
Sincerely,
Primordial Ooze
Edited by Primordial Ooze, Tue Dec 13, 2011 1:40 PM.
#2 Brian O OFFLINE
Brian O
  • 1,096 posts
  • [Custom Status Placeholder]
Posted Tue Dec 13, 2011 1:39 PM
View PostPrimordial Ooze, on Tue Dec 13, 2011 1:34 PM, said:
Hi,
Sincerely,
Primordial Ooze
You forgot to add your attachment.
-B
#3 Primordial Ooze OFFLINE
Primordial Ooze
    Dragonstomper
  • 504 posts
Posted Tue Dec 13, 2011 1:40 PM
Hi,
Sincerely,
Primordial Ooze
-B
Sorry, it's been attached now.
Sincerely,
Primordial Ooze
#4 SeaGtGruff ONLINE
SeaGtGruff
  • 4,546 posts
Posted Tue Dec 13, 2011 9:01 PM
The first thing I would do is change the way you're checking the timer. You're checking to see when the timer has reached zero, but if your kernel takes too long, the timer may pass zero before you get around to checking it. In my opinion the best way to check the timer is to check whether or not the timer interrupt flag has been set:
wait_loop
	    lda TIMINT ; the timer interrupt flag is bit 7 of this address
	    bpl wait_loop ; if bit 7 is still 0, the timer hasn't finished counting down
You can still exceed the timer's period, but if you do you'll know right away. On the other hand, if you're checking for the timer being 0 and it's already hit 0 and wrapped around, you'll have to wait for it to count down to 0 again, and hope your loop catches it the second time.
You may need to adjust the values you're setting the timer to, since the timer interrupt flag doesn't get set until the timer rolls from 0 to 255, so you'll be waiting for at least 1 more count.
#5 SeaGtGruff ONLINE
SeaGtGruff
  • 4,546 posts
Posted Tue Dec 13, 2011 9:18 PM
Also, it looks like you're using the y register to draw 191 lines, but you're also setting the timer for 199 lines. Is this all within the same frame, or on two different frames?
#6 Primordial Ooze OFFLINE
Primordial Ooze
    Dragonstomper
  • 504 posts
Posted Wed Dec 14, 2011 10:35 AM
wait_loop
I changed all the loops that used the INTIM register to bpl like you said and now all i'm getting is a black screen.
The 199 lines timer code is related to the lightgun routine posted by Eckhard Stolberg and not my code. I also changed that code to 191 lines and still am getting a black screen. It seems like we are going backwards instead of forwards. I have attached the modified source code for reference. Any assistance would be greatly appreciated.
Sincerely,
Primordial Ooze
#7 Eckhard Stolberg OFFLINE
Eckhard Stolberg
    Dragonstomper
  • 882 posts
Posted Wed Dec 14, 2011 2:27 PM
Seems like you forgot to attach the new source code again.
In the timer loops you also changed the INTIM to TIMINT (which is a different register), right? Because otherwise the bpl would end the loop immediately if the value loaded into the timer was bigger than 127 (which is the case in the lightgun position test).
Anyway, the reason why you are generating too many scanlines has nothing to do with the timers. It's simply because your ScanLoop takes more than 76 cycles in some cases. That means some instructions will be executed in a second line. These extra lines add up quite a bit in your program. If you make sure that your ScanLoop never uses more than 76 cycles between (and including) two "sta WSYNC"s in every possible case, then your display should be fine.
#8 Primordial Ooze OFFLINE
Primordial Ooze
    Dragonstomper
  • 504 posts
Posted Wed Dec 14, 2011 2:53 PM
Sorry i was very busy today doing a million things at a time! :woozy: It's attached this time!
Nope, no wonder why the screen went all black... :?
EDIT:Fixed
How exactly would i do that cause at this point I'm completely stumped. All i'm doing is displaying 2 sprites and a playfield nothing too complex. Are you saying if i add 2 WSYNC's will solve my problem cause i'm been at it for a bit now. :skull:
Edited by Primordial Ooze, Wed Dec 14, 2011 3:19 PM.
#9 GroovyBee OFFLINE
GroovyBee
    7800 Developer
  • 5,782 posts
  • Busy bee!
Posted Wed Dec 14, 2011 3:10 PM
If you can't fit the work required into one scan line you need to create a 2, 3, or 4 line kernel (as required) for your game. You need to work out how many cycles the code for each scan line will take. If you randomly add WSYNCs you won't end up with a robust kernel.
#10 Primordial Ooze OFFLINE
Primordial Ooze
    Dragonstomper
  • 504 posts
Posted Wed Dec 14, 2011 3:20 PM
Ok, so where exactly do i start?
Sincerely,
Primordial Ooze
#11 GroovyBee OFFLINE
GroovyBee
    7800 Developer
  • 5,782 posts
  • Busy bee!
Posted Wed Dec 14, 2011 3:28 PM
In your last posted source code start at line 483 and look up how many CPU cycles each instruction takes. Make sure you take into account page crossings and branches taken or not taken. When you get to line 582 you can work out where to put the WSYNCs (or not if you can break the code into chunks of 76 cycles). You might also find Andrew Davie's tutorials on sprite handling useful too (sessions 21 to 23).
#12 Primordial Ooze OFFLINE
Primordial Ooze
    Dragonstomper
  • 504 posts
Posted Wed Dec 14, 2011 3:46 PM
I was thinking about upgrading my kernel into a 2 line kernel as stated above you said adding WSYNC randomly will make my kernel unrobust. So how do i start in terms of creating a 2 line kernel?
Sincerely,
Primordial Ooze
#13 GroovyBee OFFLINE
GroovyBee
    7800 Developer
  • 5,782 posts
  • Busy bee!
Posted Wed Dec 14, 2011 3:48 PM
By working out the CPU cycles for the work required in the game. There is no other way on the 2600.
#14 Primordial Ooze OFFLINE
Primordial Ooze
    Dragonstomper
  • 504 posts
Posted Wed Dec 14, 2011 3:55 PM
So what your saying is a 2/3/4 line kernal is simply additional WSYNC's in the correct cycle count places?
Sincerely,
Primordial Ooze
EDIT: I added an additional WSYNC where the 2nd line should start along with a comment on it and it still doesn't seem to solve my problem. I have attached the latest revision of my source code.
Edited by Primordial Ooze, Wed Dec 14, 2011 4:10 PM.
#15 GroovyBee OFFLINE
GroovyBee
    7800 Developer
  • 5,782 posts
  • Busy bee!
Posted Wed Dec 14, 2011 4:12 PM
No! If your kernel takes exactly 76 cycles per scan line you don't need a WSYNC.
#16 Primordial Ooze OFFLINE
Primordial Ooze
    Dragonstomper
  • 504 posts
Posted Wed Dec 14, 2011 4:25 PM
Ok well i added the additional WSYNC as per your instructions and it didn't seem to make a difference. Could please take a look and see what I'm doing wrong as after trying to figure it out by myself and posting the source code a few time, i really seem to be between a rock and a hard place. Any assistance would be greatly appreciated.
Sincerely,
Primordial Ooze
#17 GroovyBee OFFLINE
GroovyBee
    7800 Developer
  • 5,782 posts
  • Busy bee!
Posted Wed Dec 14, 2011 4:30 PM
How about adding the CPU cycles per instruction in the comments? Then you'll have an exact idea about the amount of work the CPU has to do.
#18 SeaGtGruff ONLINE
SeaGtGruff
  • 4,546 posts
Posted Wed Dec 14, 2011 8:43 PM
A 2-line (or 3-line, or 4-line, etc.) kernel is a lot like a 1-line kernel, but your loop takes more cycles. Whether or not you need any WSYNC instructions depends on how many cycles the loop contains and how precisely-timed it is. Thus...
If your loop takes less than 76 cycles-- or really, less than 73 cycles-- then include 1 WSYNC to fill out the line and it will be a 1-line kernel. Don't forget to factor in the cycles needed for decrementing or incrementing your loop counter and testing it, plus the cycles needed to loop back, plus the 3 cycles for strobing WSYNC. Also, keep in mind that branches take 2 cycles if they aren't taken, or 3 cycles if they're taken, or 4 cycles if they're taken but the target address is on a different 256-byte page.
If your loop takes exactly 76 cycles-- including the overhead cycles for updating the loop counter, checking it, and branching-- then you can omit the WSYNC. This is still a 1-line kernel.
If your loop takes more than 76 cycles but less than 152 cycles (or less than 149 cycles), then include at least 1 WSYNC and it will be a 2-line kernel. You may not need to use 2 WSYNCs if you don't care so much about the timing on the second line. But if you need the instructions on both lines to be lined up so they always execute at specific points on each line, then include 2 WSYNCs.
If your loop takes exactly 152 cycles-- excluding any WSYNCs but including all the extra overhead stuff-- then you don't need any WSYNCs.
And so on for a 3-line kernel, 4-line kernel, etc.
Of course, the number of times you execute the loop will depend on how many lines it draws-- like 192 times for a 1-line kernel, but only 96 times for a 2-line kernel, or 64 times for a 3-line kernel, etc.
If you do go with a 2-line kernel, or 3-line kernel, etc., you might need to use a separate variable or register as an index for the graphics.
For example, a simple 2-line kernel might look something like this:
	  ldy #0 ; index for the graphics
	  ldx #96 ; counter for the loop
loop
	  lda (graphics_vector),y
	  sta GRP0
	  ; do some more stuff
	  iny ; increment the graphics index
	  sta WSYNC ; finish off the first line
	  sta GRP0
	  sta WSYNC
	  dex ; decrement the loop counter
	  bne loop ; not done yet? then loop again
Since updating the loop counter, checking it, and looping back take time, you might want to put the first WSYNC at the beginning of the loop so the instructions for the first line are always lined up exactly the same as the instructions for the second line...
loop
	  sta WSYNC ; finish the current line and start a new line
	  sta GRP0
	  sta WSYNC ; now finish this line and start another new line
	  sta GRP0
#19 Primordial Ooze OFFLINE
Primordial Ooze
    Dragonstomper
  • 504 posts
Posted Thu Dec 15, 2011 11:22 AM
loop
	  sta GRP0
	  sta GRP0
	  sta WSYNC
loop
	  sta GRP0
	  sta GRP0
Thanks, i managed to do exactly what you said and got a stable scanline count. What i would like to know is if i did it correctly because for some reason, my player0 is slightly messed up having pixels where there shouldn't be(see beak) and colors that shouldn't be(beak is black, back of head color is incorrect). Once we manage to get these bugs fixed i will test it on a real atari and let you know the results. Any assistance would be greatly appreciated.
Sincerely,
Primordial Ooze
#20 SeaGtGruff ONLINE
SeaGtGruff
  • 4,546 posts
Posted Thu Dec 15, 2011 7:53 PM
When I run it in Stella and step through the program in the debugger, it looks like GRP0 is being set before the scanning beams reach the duck, but COLUP0 is being set after the scanning beams have passed the duck, so it's probably related to timing more than anything. I don't know if the duck will always be at the same spot on the screen or will be moving around on the screen. If it will always be at the same spot then you may just need to update the x index before you load the colors, or rearrange the color table a bit-- in other words, when you set GRP0 to the left of the duck, you're setting the graphics for that line, but when you set COLUP0 to the right of the duck, you're setting the color for the *next* line, if you see what I mean. Otherwise, if the duck will be moving around on the screen, you'll want to see if you can reorder some of the instructions so GRP0 and COLUP0 are always set during the HBLANK period.
#21 Primordial Ooze OFFLINE
Primordial Ooze
    Dragonstomper
  • 504 posts
Posted Fri Dec 16, 2011 9:52 AM
Ok, where exactly in code does the horizontal blank period occur? Is it the part of the code where the controller checking and game logic occurs considered the horizontal blank period? Any assistance would be greatly appreciated.
Sincerely,
Primordial Ooze
#22 GroovyBee OFFLINE
GroovyBee
    7800 Developer
  • 5,782 posts
  • Busy bee!
Posted Fri Dec 16, 2011 10:11 AM
This is a useful image when 2600 coding :-
http://www.atariage....timing-diagram/
A refresher of the tutorials before that would probably help too.
#23 Primordial Ooze OFFLINE
Primordial Ooze
    Dragonstomper
  • 504 posts
Posted Fri Dec 16, 2011 10:57 AM
Thanks for that image. I read the tutorials and know how a game image is drawn on a tv screen. However i'm having a bit of difficulty trying to associate the timing with my code as my project is getting quite complex! Anyway based on the image and the following quote Session 2:
Quote
Horizontal Blank when the beam is resetting to the left of the next scanline
My guess is the code should be between
    dey                                    ; subtract one off the line counter thingy
    bne ScanLoop
or
ScanLoop
    sta WSYNC
Please let me know if i'm correct and advise me which one is the correct answer. Any assistance would be greatly appreciated.
Sincerely,
Primordial Ooze
#24 GroovyBee OFFLINE
GroovyBee
    7800 Developer
  • 5,782 posts
  • Busy bee!
Posted Fri Dec 16, 2011 11:06 AM
You really need to start working out the CPU cycles each instruction takes and putting it in the comments then you'll have a much better idea about when the registers are updated to the relative position of the scan line.
#25 Primordial Ooze OFFLINE
Primordial Ooze
    Dragonstomper
  • 504 posts
Posted Fri Dec 16, 2011 12:15 PM
That seems like a lot of work. This project is starting to get the best of me and i may end up abandoning it. Isn't there another way besides counting cycles?
Sincerely,
Primordial Ooze
