I understand... although I've never been in the market to spend $3K on a cabinet.
Instead I've made my own cabinets.
- I started with X-Arcade control panels, played games with emulators, and figured out what additional controls I wanted ($200 and time).
- Added an old PC or Mac, then graduated to a 22W nettop that plays all of the games I care about ($250, and it's also a media PC that does HDTV)
- I build various cabinets, but the only things I had room to keep were "bartops"
- I built 2 upright cabinets with LCDs, but had to move and they couldn't go with us, plus I liked CRT displays better
Basically, you can have anything you want, even if you don't want to do any major work. Find a design you like online, give the design to a CNC woodworking shop and get the design cut from the lumber, then simply assemble the parts, paint it, and put everything into it. You might have to go through the horrible experience of getting a custom sized sheet of glass or lexan cut for your display area (sarcasm, it's easy). Even if you don't want to deal with wiring the control panel, just buy an X-Arcade and install the parts from that (You can always upgrade or add other controls later if you want.). Put a cheap PC inside, then choose a CRT.
You will have the exact monitor, controls, and cabinet you want -- and it will probably be 1/2 to 2/3 the price of the machine you are currently looking at. Best of all, it will be perfect for you and play every arcade game, console game, and handheld game possible.
The cabinets I've built won't be breaking for 50 years unless they've been left outside in the the rain and snow. The pre-made cabinets I've seen will last 10 years with kids (maybe 20 with only adults and never a beverage around), but then they're going to look ragged because they're made from particle board. Chips, moisture, everything screws up particle board.
There are so many options.... perhaps fewer than 10 years ago, but still many...
