You dont want that.. Use this instead:
http://www.horus.com...tari/sram13.zip
It's much better,easier, costs less, does alot more, and puts alot less capacitance/load on the bus..
If you plan to extensively mod the machine, you need to realize that everything you hang off the data bus increases the propogation time on the bus, and can potentialy cause stability issues when the bus timing gets far enough out of whack in relation to PHI2. 1 Sram chip is alot better than 8 additional drams.. Plus, with hias's mod, you get 576k, and the ability to make it nonvolatile (by adding a small battery) if you want..
