Posted Sun Jan 1, 2012 9:40 PM
I agree with Rybags. Make a sector copy of the hard drive you are using, ie. '....,or at least do a raw dump backup using PC'. There are utilities to do sector copy of a hard disk. How big is your disk? You'd need
a APE/SIO2PC cable or something else that would allow a 16 meg or whatever your drive is. I have a utility that you can make a file sector copy of the hard drive, if it has 256 byte sectors.
Once you have dumped the drive to a file that can be manipulated with a PC you can safely work on the image. Probably someone that made the SPX 4.45 can help you more.
