0
Odd Atari Lynx 2 Problems (No sound...)
5 replies to this topic
#1 P5ychoFox OFFLINE
P5ychoFox
    Space Invader
  • 18 posts
Posted Thu Jan 12, 2012 2:40 PM
My newly acquired Lynx 2 has some odd problems:
It has no sound through the speaker or via the headphones socket. Is this a sound caps issue?
Also, the A and B buttons are activating on their own. E.g. on Kung Food, the main sprite just punches and kicks continuously. The D pad is ok though....this could be that the casing has been removed and put back on incorrectly - I hope so :)
Any ideas how to fix these issues?
Edited by P5ychoFox, Thu Jan 12, 2012 2:41 PM.
#2 sage OFFLINE
sage
    Moonsweeper
  • 391 posts
Posted Thu Jan 12, 2012 4:26 PM
for A and B, just clean the contacts below the buttons. they use graphite for getting the contact, and somtimes there is a little graphite dust under the button. is this is not working yet, it might be that the rubber is a bit old. what you can do then, is to add a small additional spacer, like a piece of paper or tape with a hole wher the contact has to be.
#3 karri OFFLINE
karri
  • 1,049 posts
Posted Sat Jan 14, 2012 6:25 AM
This is a very common problem that comes when someone plugs something wrong into the headphone socket. It fries the speaker. Usually people plug in the AC/DC adapter there.
The first thing is to disconnect the speaker and test the headphones again. They may work now. It is easy to find a same size speaker from some electronics component store.
Karri
#4 P5ychoFox OFFLINE
P5ychoFox
    Space Invader
  • 18 posts
Posted Sat Jan 14, 2012 2:09 PM
Karri
Many thanks Karri, I'll try that.
#5 P5ychoFox OFFLINE
P5ychoFox
    Space Invader
  • 18 posts
Posted Sun Jan 15, 2012 6:57 AM
Karri
If I need to replace the speaker, would a Game Gear speaker work as a substitute?
#6 P5ychoFox OFFLINE
P5ychoFox
    Space Invader
  • 18 posts
Posted Sun Jan 15, 2012 7:58 AM
Just disconnected the speaker and still no sound through headphones :( Must be a caps issue?
