(non HSC players feel free to add to this too)
I'll start by listing the level codes for Fandal's Diamondz
1 press start stupid!
2 zbahet
3 sabfac
4 xurred
5 bovcap
6 jedoof
7 atruzw
8 gobzak
9 pudres
10 ydeqat
11 kroafu
12 neebuc
13 oxaneh
14 pragut
15 ryvnok
16 spuzak
17 hrofuj
18 cagbra
19 qupevo
20 fynjed
21 rekras
22 bonhra
23 acubro
24 kystan
25 rokjup
26 vapsol
27 frahyg
28 toaped
29 uzuron
30 pastuc
31 vorxef
32 gobsad
33 jagmnon
34 souhev
35 kayzuf
36 bragod
37 repund
39 asrajo
40 votran
41 xubree
42 fotsyh
43 epazug
44 dekvor
45 tunsab
there may be a few errors here as my writing is shocking, combined with my typing errors, in theory should correct any mistakes
Captain Beeble
press select in game for slow or fast objects
Ollie's Follies
press esc for pause as Ollie is falling off for strange sound effects!
codes FRANK FANDA NORBI ZOOOM (type in game)
Bounty Bob Strikes Back
some bits from earlier this season:
Now some fun stuff to take a look at:
If you struggle on level 2 use the utility hoist to do the left side (get the top two bugs from the first object) then the 3rd platform down, then to the bottom and just kill the bugs in the bottom left be sure to get the other bug by jumping up! If you have problems with the single square you can do a big jump from the very left hand wall to get back onto it! Then you can go all the way to the top right platform and you don't need to use the Gravity lift again you can do the entire right side/bottom of the screen with jumps and drops
On level 4 instead of going down the left and right ladders did you know you could make the jump from the plaforms to the middle slider?!
Put the code 61,800 in the options screen (press fire to move code in blocks of 100), hold F and press Option, then start your go, type 02 to warp to level 2 (you can jump to any level using this method) press F to float around the screen, go right to the very top, alongside the gravity lift then press F to turn the float off... have fun!!! (keys A, B, Q, Z also do things)
